Question about Fuji FinePix J10 Digital Camera
I can't get my battery out
The battery doesn't pop out when I move the lever. I have tried pushing on the battery slightly, but it appears to be stuck and I don't want to apply too much pressure. I need to recharge the battery.
    President:
  • 423 Answers
Try using some thin tweezers or "duck-billed" pliers. The most likely cause is the battery being inserted in the wrong direction. Take the memory card out first, as this allows the thin wall of plastic to move just enough that you should be able to grab the end-cap of the battery.
Posted on Jul 04, 2009
How do i manually retract - Exterior door stuck closed - removed knobs (levers)
PUT A SCREW DRIVER IN THE HOLE AND TURN IT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/joe_0ca6379e2eceb740
May 25, 2014 | Kwikset Lido Polished Brass Entry Lever...
Sony vaio vpcm13m1e
I have been stymied by laptop batteries myself. Look for other ways to move it. If you are sliding the battery, try pulling up on the edges. There are sometimes two switches on the bottom. One to lock the battery in place, the other to release the battery. Try different combinations of the release switches.
Sep 25, 2013 | Computers & Internet
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
2007 Kawasaki Ninja ZX6R shift lever does not return
Hi, Free2b_ameri and the usual suspects are:
1. Shift linkage bent.
2. Shift linkage contaminated needs cleaning and lubrication.
3. Return spring bent or broken.
4. Shaft shaft bent.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Shift lever doesn always come back up KawiForums Kawasaki Motorcycle Forums
Shift lever doesn return after downshift Kawasaki Forums
Kawasaki Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja ZX 6R Owner Manual
May 02, 2012 | 2007 kawasaki Ninja ZX6R
My battery is dead and I can't move the car due to the auto gear shift stuck in park. How do I move the car to get a jump on the battery?
if you look on the center council where the shift lever is you will see a small plastic button on the drivers. Remove the button. Insert a small screwdriver into the hole and push down. You will then be able to move the shift lever into nuetral and push the car.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 06, 2012 | 1997 Toyota Camry
1987 xjs hood is stuck car has been sitting for years
it lifts from the back and tilts foreward ,their are two cables running from the interior lever ,best thing is for you have a look at another one and if you can jack car up and try to reach each lever in turn with a long screwdriver and push or pull it with a wire .best of british with it
Jul 09, 2009 | 1987 Jaguar XJ6
Spp 2040 printer ribbon
  • Open the door on the right side of the printer.
  • Push "up" on the green lever above the ribbon cartridge. The ribbon should pop out slightly.
  • If it does not pop out, then try prying out the cartridge while pushing up on the grean lever.
  • Pull out the ribbon cartridge.
Feb 14, 2008 | Samsung SPP-2040 Photo Printer
Frigidaire ice dispenser problem
The ice anger will be controlled by a motor system, the hummming could bea result of stuck rotor or the motor system is faulty. the motor might needs replacement.this will explain why the ice is not dispenced.
Aug 10, 2007 | Frigidaire GLRS264ZA Side by Side...
Fuji FinePix J10 Digital Camera Logo
59 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
