Question about Sunbeam Heating & Cooling
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
    Problem Solver:
  • 18 Answers
Check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Posted on Jul 02, 2009
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
My Whirlpool window a/c is not cooling as well as it did last sum
I know it has been at least a year since your post. I am answering the post to terminate FixYa site activity on the post.
Remove the front cover. Check the routing of the temp sensor wire. It should go from the bottom of the control panel to the plastic clip in the evaporator coils. If it is touching the eavporator coils it will sense the refrigerant temp and cycle off early. If the unit is freezing up there is a restriction in the coolant lines and usually will require the coolant system be purged of foreign internal debris.
Thanks for choosing FixYa.
Kelly
Jun 25, 2009 | Whirlpool ACC108PS Air Conditioner
My room air conditionar is not blowing out cold air,please help
if the compressor is running then the refrigerant has leaked out and repairs on that are 140usd+ , check the warranty on it.
Phil
Jun 10, 2009 | Heating & Cooling
Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Apr 27, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
298 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
