Question about Sony VAIO VGN-S460 Notebook
Space Bar i have the space bar but other than that im missin two pieces: the black thing that lets u click the MIDDLE and the white thing that helps u click the RIGHT part (i have the LEFT part) HELP MR OR I'LL GET IN HUGE TROUBLE...I THINK
  • 46 Answers
Only way that i see, is that you must go to a reseller to try u to arrange the pieces. There is no other way.
Posted on Nov 09, 2007
How do I download a manual for Samsung T105G?
To download a manual type in your browser manual for Samsung t105g, you should be able to prprig it. To space on your tracfone you press on the right side of big square bar in the middle and press to the left side to back space. Hope this helps!
Sep 15, 2014 | Samsung Tracfone Sgh T105g Cell Phone...
The space bar seemed wobbly so i took it off to try and fix, and the clips and all came off. I am somewhat good at technology and figuring things out but i cannot get this space bar back on. How do i fix...
That depends on what kind of clips it used. Most laptops use these small plastic clips. Assuming it is not broken, you have to first connect the two plastic pieces together properly. This is noted by it laying completely flat and freely able to move around. Then place it back on the space bar as it will have slots it must slide into. Then place the bar back over the space it came out of with the plastic henge over the square space with a popup switch and press firmly until you here a click. It should lock into place.
If you continue to have trouble, take it to a professional. Something like this should be cheap and quick to get fixed.
May 14, 2011 | Computers & Internet
My spacebar key is no longer working properly. I have an acer aspire laptop 5735Z . I deliberately pulled the key off to clean underneath and then just clicked it back on, thinking it would work normally....
There is usually a metal piece under the space bar, if it isn't seated properly the space bar will teeter. Try to remove again and see if they metal bracket is seated correctly.
Oct 18, 2017 | Acer NSK8458AN Keyboard
Wont show up on my computer
Firstly, make sure that all the cables are plugged in properly for power and USB data transfer. If it still doesn't show up after a few minutes, then Right-Click on My Computer (Vista & Win7 users will see it labeled Computer), then choose Manage, then choose Storage, Then Disk Managment. It will take a few seconds for your computer to fully load in the screen. At the top it should list your hard drive or hard drive partitions if you have more than one partition. Under that you will see Disk 0, Disk 1, and so on. Do you see any of these with a long black bar to the right of it with it labeled Unallocated Space inside the box area under the black bar? If not, then there is something severely wrong with your My Book or the power or USB cables to it, or your computer's USB port is burned out, try all of your USB ports just to be sure. If you do see a long black bar that says Unallocated Space underneath it, then this is likely your My Book. Unallocated Space means that the hard drive hasn't been formatted yet, or that it's partition has somehow been deleted. If you've used this external hard drive in the past to back things up on, then your data is lost because data can't be stored or retained on a hard drive that isn't formatted or partitioned. Be sure that the area of Unallocated Space is actually your My Book. It should show how much Unallocated Space there is, and your's should be reading between 300GB - 320GB. To get your computer to recognize your hard drive you will have to partition and format it. Right-click in the white area under the black bar and choose Create Simple Volume. Follow the steps thru and format the hard drive. After its formatted it should be recognized by your computer again.
Sep 15, 2010 | Western Digital My Book (WDG1C3200) 320 GB...
How to use the space bar when typing on screen keyboard?
If you are typing with the mouse, just click the space once to give one space after a word or after a letter. There's no other method or no other way to give space without using the space bar of the onscreen keyboard.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 24, 2010 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
Oct 10, 2009 | Dell 0Y3740 Keyboard
First & Third space in GE TPL412RP are hot, second &fourth not
This is not 3 phase have two legs of 120 ...the red wire? This leg is not a voltage source therefore that wire is not going to fire up that lug only need 3 wires to make this circuit and a neutral is a redundant leg for this box
Jun 28, 2009 | General Electric G.E. - INDUSTRIAL SYSTEMS...
Spacebar on IBM Lenovo ThinkPad X61 came off.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Apr 12, 2009 | IBM Lenovo ThinkPad T61 Notebook
Space bar
If the bar works when you hit right in the middle try reinstalling the bar the metal rod must go under the tabs on the keyboard, if it won't at all you probably need a keyboard.
Jun 02, 2008 | IBM 3500 Typewriter
Space bar sticking on Saitek lighted keyboard
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Feb 21, 2008 | Saitek Eclipse II
Sony VAIO VGN-S460 Notebook Logo
42 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
