Question about Frigidaire GLWS1233A Top Load Washer
Washer doesn't run correctly
A belt from my robe got caught in the agitator and now when I have tried to use the washer it will fill with water, but won't start the cycles and it smells burnt.
    Problem Solver:
  • 6 Answers
You probably blew the motor. Ensure something isn't still caught, aka do you have the full belt or did it tear. Something could be wrapped around and stopping movement. Does the agitator shudder or move at all, can you hear anything moving? If it's totally silent the motor is very likely dead and you'll simply have to replace it.
Flip it over and you'll find some large lug nuts that attach the motor to the tub. The whole piece is usually pretty easy to take off and replace. Though it will be heavy.
Posted on Nov 09, 2007
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
Jul 11, 2013 - Uploaded by
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Why does washer stop agitating after few minutes?
Check for something caught in the pump or under agitator.
Check that the belt underneath is free running.
This fault is usually associated with excessive current & the motor going out on the auto reset overload.
Could be motor trouble, starting capacitor (If fitted) or the timer.
Jun 29, 2015 | Kenmore 24032\24036 Top Load Washer
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
Washer filled up but will not agitate or
Does the motor run? May be a tripped circuit breaker on the motor. If motor runs, may be a broken belt.
Jul 27, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Frigidaire GLWS1233A Top Load Washer Logo
44 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
