Just installed this year and close passenger door and stereo stops working
SOURCE: xm stopped working display says "antenna"
Broken antenna cable. Likely you have a kink or worn thru point on the wire somewhere.
SOURCE: I installed a pioneer Deh p49001b car stereo in a
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
