Question about Pioneer DEH-P80MP CD Player
No power in the faceplate, only ejecting the disc is works fine
I checked the fuses etc and no luck. The unit didn't want to turn on withiut restarting the ignition for last few weeks and now is dead. Only ejecting the disc and lowering the faceplaqte is not a problem, rest of the buttons and faceplate light don't work.
I see there was somebody having the same problem, so it is common failure I'd say.
The only thing what paid my attention was the wire tape between the unit and the bracket, which looks weird, like broken in a half. Not sure if this is a problem.
Can this be fixed?
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
Try this take ur stereo out and connect ur power and contant together. than go to ur car baterry and connect the red with the constant to the positive and the bleck to ur negative in ur batery and if it turns on than u r missing a connection on ur hook up test first if it dont work than its defected if it does work make sure u have the consant conected too and a good ground
Posted on Jul 02, 2009
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
XHDR6435 radio was working fine yesterday, now it will not turn on. the red led behind the faceplate flashed when i turn on the car, and cds will load and eject but the radio will not power up. i habe...
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Jun 14, 2011 | Dual Electronics XHDR6435
Attached cd player worked fine with cd then next time turned unit on it only shows symbols on the display n does not work no buttons work can't turn off and can't eject disc any ideas?
Most CD players will have a very small hole you can fit a paper clip into and push it
in which releases the CD drive mechansim and starts opening the tray.
You may want to press the RESET button behind the faceplate first and see if rebooting
it will make it cooperate. If you dont have the detachable faceplate completely on
some of the symptons you describe could happen.
Mar 26, 2011 | JVC KD-G421 CD Player
When we turn the power on iit only stays on a few seconds then turns off with the cst.in light flashing.. what does this mean and what can we do to fix it?? tks
I had the same problem. We watched a DVD, and the unit worked fine. We went out for ice cream, came back, and decided to watch a VHS. Instead of taking the VHS, the CST.IN light flashed and the unit cut off after a few seconds. We didn't have a VHS in the unit at the time. After cutting the unit back on several times without success, I looked online for solutions. One person said to hit 'eject' 5 times in a row, but that didn't work for my unit. Someone else said there was a lever inside near the power button that ejected the VHS, so I checked that out next. I washed and dryed my hands well, and used my finger to jiggle the white lever. Then I saw that the tray that the VHS sits on wasn't all the way forward, so I gently pulled and pushed it. I'm not sure which of the two actions worked, but my light is now a steady green and my unit is working fine now. I am so glad because we've had this unit for almost 10 years now, and I really didn't want to have to buy a new one! Good luck!
Jan 17, 2011 | Emerson EWD2202 DVD Player/VCR
Can not get the magazine to eject have a fuse but everytime i reset the fuse i get a little juice but then nothing, What fuse should be used on this unit and where is the manual eject/
you have to open the cd changer and you will notice that 2 or 3 disc move to the right side under the tray or on top
pusch them back into the cd magazine but don't force the unit and don't move the disc on the tray
now power it again and press eject
good luck
Nov 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
I can't seem to get the get my pioneer deh-980bt to power on. i check wiring and still dont' power on.
check fuse at back of unit. also pull the plug out of the head unit & check for power at the pins in the plug that fits to the unit.
Aug 23, 2009 | Pioneer DEH-P980BT CD Player
No power to Kenwood KDC-4019 faceplate
It sounds like the stereo does not have the "ACC" voltage. It could have blown a fuse. The "ACC" voltage goes to the red wire on the harness and you get that voltage turned on only when the ignition is turned on in the car.
The symptom of the disc ejecting and nothing else works is an indication that only the constant voltage for the yellow wire is connected. Check the voltage on the red wire with the car turned on, if you have that 12 volts at the red wire, then you need the radio serviced.
It is not very likely that the faceplate has gone bad. Just because the radio will not turn on is not an indication that the faceplate is bad. It could be a voltage regulator in the radio or a circuit trace is blown, or almost anything else. There are many reasons that the radio would have the problems you describe and it can only be found out for certain by troubleshooting the radio on a test bench with the proper tools. If you have a multimeter and a power supply I can guide you thru troubleshooting the radio and even email you the service manual in PDF format if you would like to take a crack at it yourself.
Let me know how you want to proceed.
Dave
Oct 25, 2008 | Kenwood KDC-4019 CD Player
DVDR 3350H KEEP READING AND WON'T EJECT DISC
Look under the faceplate where the disc tray ejects and see if there is a small hole. If so, use a straightened paper clip to eject the disc manually by pushing it into the hole about an inch. If that works, then reset the power on the unit and try a nonrecorded type disc to see if the unit works at all.
Other than that, you'll have to take the unit apart to get your disc out.
Hope that helps...
Geno
Mar 24, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Pioneer DEH-P80MP CD Player Logo
259 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
