I have installed a Hunter fan and light remote control, Model 27185. It works fine. But (with wall switch on) if I turn the light on with the remote and turn if off at the wall switch, the light does not come back on when I turn it on at the wall switch. I have to turn on the switch and then use the remote to turn on the light. It seems like I should still be able to control the fan light with the wall switch.
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
I bought two remotes for two different Hunter fans. Installed both per manufacturer's instructions -...
(More)
I bought two remotes for two different Hunter fans. Installed both per manufacturer's instructions - (those could be improved in regards to dip switches & jumpers). Situation is that both fan controllers respond to the factory settings no matter how the dip switch settings are changed. One remote control with factory settings will activate both fans & lights no matter what the dip switches on the fan controller are set for. Change the remote's jumpers and it doesn't work even after matching the dip/jumper settings. Haven't tried disconnecting the power to see if this fixes the problem. Know a little about electronics but this one has me baffled.
Having trouble install my hunter 27157 remote for ceiling fan take that back my husband is having...
(More)
Having trouble install my hunter 27157 remote for ceiling fan take that back my husband is having trouble figuring out which wires connect , can anyone help
Since Carrier does not have the original remote for my unit (rfl-03010EH) a distributor sold me the...
(More)
Since Carrier does not have the original remote for my unit (rfl-03010EH) a distributor sold me the new one. It does not communicate with the unit. I see 7 dip switches but no instructions come with it. HELP
