Question about Coleman Mach III Air Conditioner
Do you come across many leaks in the evaps of these units. I cant seem to find my leak of R-22 the unit is a coleman mach 3 rv unit.
  • j92jimmy Jul 03, 2009
    I put a tap valve on the coleman mach 3 and when I put my gages on there was no gas in the unit.I scrapped the tap valve and installed 2 solder in shraders into the low and high side. after this, I pressure tested and ran my leak detector on everything I could without running it over the evaporator because it is encased in metal, I just figured it was an evap leak, because I lost my whole charge again. The evap is the only thing I didnt really leak check. thanks for any input. ps is the evap easy to access?
  • Jeff Myers May 11, 2010
    Why do you assume that the unit is leaking? What are the symptoms? It is very rare that a coleman mach III leaks out any freon.
    Novelist:
  • 127 Answers
Yes, the evap is easy to access. On the upper unit, remove the metal cover that is on the front. There are screws down both sides and across the top and bottom. Once this is removed, the evaporator is right there. When you pressure tested the unit, did you lose pressure? If you have schrader valves soldered on the unit, then you should be able to run a vacuum on the system or pressurize it with nitorogen and see if you actually have a leak. Let me know what you find out.
Posted on Jul 03, 2009
  • 614 Answers
These units do not hold much gas. Look for oily spot on coils. Once it is gased up. Use some dishwashing liquid to find your leak. Rus
Posted on Jul 02, 2009
  • James Stopp
    James Stopp Jul 04, 2009
    The evap access is not to bad. Sounds like you know what your doing. Good luck Rus
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
Today the blower motor started running slowly,approx.half normal speed, both high and low setting,on our Coleman Mach 3 ac unit.I believe it is orig.in our '87 Hoilday Rambler.Any ideas would be much...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 26, 2010 | Coleman Mach III Air Conditioner
HOW OLD IS MY UNIT? IT'S A TSR MACH 3 WITH BLUE LETTERING THANKS
GO TO rvcomfort.com
Feb 20, 2010 | Coleman Mach III Air Conditioner
We have a Mach III coleman AC unit... a little
Sounds like the evap coil is dirty or its low on freon.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Need a schematic for Coleman 6759 mach 3
GO TO rvcomfort.com
Aug 20, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Jun 01, 2009 | Coleman Mach III Air Conditioner
Coleman mach air
Time for a spring cleanning,, especially the drainnage system, filter,, front cooling coils-and the drain line! thank you-very-much!
Aug 28, 2008 | Coleman Mach III Air Conditioner
Coleman Mach III Air Conditioner Logo
131 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
