Question about Dynex Computers & Internet
My dynex 800avr battery outlets no longer function, there is a light on that sais,''wireing fault'' is there some way of reseting or recharging the Unit to make it work again.
5 Suggested Answers
  • 124 Answers
SOURCE: 'Battery' outlet dead.
Hi There, Its definately the battery. The batteries can be replaced.
Posted on Nov 05, 2008
pravinbhavsa
  • 348 Answers
SOURCE: Dynex TE685AVR - wiring problem light on
yes first disconnect the pin of load then switch off ups then switch on check ac voltage at output if comes and disappears when load is connected then battery is faulty it shows voltage without load but disappers when load is connected replace battery
Posted on Nov 09, 2008
  • 28 Answers
SOURCE: Dynex Te685avr backup battery doesnt work
The sealed batteries in these last about 6 years. You are correct in thinking that you may need a new one. Very easy to install. Here's a supplier of these: http://www.batteryinternational.com/dynex-te685avr-ups-battery-ups-batteries-f1.html
Posted on Jun 02, 2009
  • 84 Answers
SOURCE: the battery backup side is not working other side works
Its most likely caused by a dead, failed battery or a bad connection with the battery inside the unit.
Double check the connections inside the unit to ensure the battery is connected properly. If it is, take a volt meter and measure the strength of the battery. A 12v ups battery should read about 13 volts.
Posted on Mar 31, 2010
Sylvania sa 140 digital timer
Sylvania timers often come with long warranty. Call 888-548-4484/ hardwareinnovations.com
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
Usually if batteries are changed, you want to reset timer. Press reset button, for 5 seconds and then reprogram. If functionality is not restored after reset, then timer has gone bad.
Check outlet for power, makes sure bulb is working, turn light on, try timer on different outlet and with different lamp.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 08, 2013 | Hardware & Accessories
I can not set up my Digital Lamp Timer model DT300
Copy following link to identify timer and download possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
Reset timer to clear memories.
This is older timer no longer manufactured.
If functionality is not restored after reset, the internal rechargeable battery may be bad.
Don't buy used timers from ebay.
Replace with newest line of inexpensive timers: choose from 1-2 outlets, grounded or polarized. Outlets have same programming schedule.
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Apr 05, 2013 | Hardware & Accessories
Dv6000 not charging
If your charger is functioning good and you have checked for proper voltage at the tip. should be 18.5 to 19 volts. Then most likely your battery has dead cells and will no longer accept a charge. These laptop Lithium Ion batteries do not do good with being run all the way down and then recharged back up. it destroys them, they are only good for so many recharge cycles before they fail. Laptops should be left charging all the time when near an outlet and only should be used on battery when an outlet is not available. Change out your battery and everything should be back to normal. Ebay has them for around 36.00 US dollars.
Jun 29, 2010 | HP Pavilion dv6000z Notebook
Razor will not take a charge, will only function when plugged in.
Sounds like the batteries are shot. They can be replaced if you're handy with a soldering iron.
Apr 30, 2010 | Norelco Rechargeable Cordless Men's Razor...
The battery backup side is not working other side works
Mar 27, 2010 | Computers & Internet
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
Jun 02, 2009 | Dynex (TE685AVR) UPS System
Dynex TE685AVR
You need to replace the battery in your UPS. I went to the mfg. to find your model but i was unable to find the model you had posted. You should be able to take the battery out and go to a retail place like battery plus to get the battery you need. If not you may be able to get it from the manufacturer.After replacing the battery you should fine.Here is a link to the web site.
http://www.dynexproducts.com/c-6-surge-protectors-and-upss.aspx
Jan 10, 2008 | Dynex (TE685AVR) UPS System
Cannot recharge iRiver iHP-120 battery
Battery replacement directions are advaliable from misticriver.net.
Oct 06, 2007 | iRiver iHP-120 MP3 Player
Computers & Internet Logo
495 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
