Question about Panasonic KX-T7456 Corded Phone
HOW DO I CHANGE DEFAULT LINE
WOULD LIKE TO CHANGE INCOMING LINE TO RING ON LINE 1 INSTEAD OF LINE 4
  • Carl Navarro
    Carl Navarro May 11, 2010
    You need to be more specific. Do you mean the 4th button from the bottom lights up when the main number is dialed? Does it say CO4 on the display? What happens when another caller calls in?
  • 112 Answers
Use your phone settings to change incoming call
Posted on Jul 02, 2009
There is now no ring associated with incoming calls on line 3, but otherwise that line functions for both incoming and outgoing calls
http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
page 80,do this first,
25611223-5sp5orn0xnhdqraxk0v0421v-4-0.png then if you want to reset both phone and base,
clear base unit settings to default,
1 Press {MENU}. 2 Scroll to "Initial setting" by pressing {<} or {>}, then press {ENTER}. 3 Scroll to "Initialize base" by pressing {<} or {>}, then press {ENTER}. 4 Scroll to "Clear settings" by pressing {<} or {>}, then press {ENTER}. L The "Clear settings?" screen is displayed. 5 Press {CLEAR}. L Confirmation tone is heard.
clear handset to default,
Press {MENU}. 2 Scroll to "Initial setting" by pressing {V} or {^}, then press . 3 Scroll to "Initialize HS" by pressing {V} or {^}, then press . 4 Scroll to "Clear settings" by pressing {V} or {^}, then press . L The "Clear settings?" screen is displayed. 5 Press . L Confirmation tone is heard.
Mar 27, 2015 | Panasonic KX-TG4500 Phone
Hi this is fortune. i had a phone prostar samsung at the office. i think it loose the wire. when there's incoming calls i can't hear the ring. what shall i do?
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Oct 06, 2010 | Samsung Prostar 816 Phone
My Prostar 816 will not ring. The lines will light up and flash when there is an incoming call, but I have no ringing sound. How do I get my telephone to "ring"? Thank you!
Sep 01, 2010 | Samsung Prostar 816 Phone
Some 816 phones won't ring on incoming calls
Jun 05, 2010 | Samsung Prostar 816 Phone
How to change silent mode to normal mode, the phone line it's fine, I just can't hear the incoming calls
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset2_bing.gif)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
Dec 15, 2009 | Samsung Prostar 816 Phone
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
I would like Line 6 on Norstar System to Ring Different
Normal 0 To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
Jan 15, 2009 | NorStar M7310 Corded Phone
Need to program extension to ring on incoming calls
Professional Level 1 programming to make a phone ring on incoming calls:  1. On the phone you want to change ringing, press <FNC> - 4 and the screen will show the port number and the station number. If it doesnt have a display, borrow one and plug it into the cord that is attached to the wall, then do this. The port number is needed since all station programming is port based.
2. From ext. 10 or 11 (or whatever the extension numbers are for ports 01 and 02 are), with the phone idle press ,<FNC>, <HOLD>, #,0,*. The screen should show "PROGRAM MODE".
3. Press Line Key 4, which is the 4th button across the top. Dial "15", screen should show "01 / 15: 12345678" if you're in the right place. In this mode, the * key moves the cursor right, and the # key moves the cursor left. The first two digits are the port you're programming, the next field is the program code, "15"in our case, which is Daytime Ringing, and the last field is the data setting for this port.
4. Move the cursor to the left so you can change the port field to the port number you found in step 1. After changing the port number, move the cursor back to the right to the data field, and press the digits corresponding the the line number you want to ring, e.g. for line 1 press "1", for line 4 press "4". Each digit pressed in this field is a toggle, so if you press "1" when the digit "1" is already displayed, you will turn off ringing.
5. Verify that the display settings are correct. For example, if you want port 04 to ring in day mode on lines 3, 4 and 5, the display should show "04 / 15:   345    ". If all is correct press <TRF>, and note that the screen advances to the next port automatically.
6. You can change Night Mode ringing by setting the program code field to "16" instead of "15", then the same procedures apply.
7. When all changes are completed, press <SPKR> to exit program mode (or lift handset and hang up).
Dec 16, 2008 | NEC Electra Professional ETW-16DC-2
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Panasonic KX-T7456 Corded Phone Logo
179 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
