Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Module ice maker not working no water
Water is on to the frig. can I jump between L & V terminals to see if the water valve energizes? I have thawed the metal water line.
Thanks a bunch
Ralph
  • 351 Answers
Yes i do it all the time but make sure it is 110 volts some are only 24 i think
Posted on Jul 02, 2009
I have a maytag side by side frig model # msd2578vemoo the ice machine works but the water dispenser does not work
You will need to replace the water inlet valve on the back of the refrigerator. One line is for the water dispenser and the other is for the ice maker. The side for the ice maker is not energizing the solenoid to let the water thru to the ice maker. Here is the part you need to order.
Nov 10, 2012 | Refrigerators
Whirlpool refriigerator ice maker not working
With ice makers it is almost always one of two things. The ice maker itself, or the water valve. Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
May 29, 2010 | Whirlpool GS5SHAXN Side by Side...
Ice maker won't make ice
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker.
May 29, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker stopped making ice
With ice makers it is almost always one of two things. The ice maker itself, or the water valve (valve is located on the backside of the frig, bottom right hand side almost 100% of the time). Figuring out which one is easy, and I will help explain.
May 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped making ice...no water coming into maker nor does the unit appear to be rotating...water dispenser works fine.
Quick facts: If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
May 28, 2010 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
THe ice maker is not making ice. The red light is flashing.
A weird coincidence. Simply taking out an ice container shouldn't cause problems of course, nor should turning off the water to the house. I'll give you my normal explanation of it being either the ice maker or the water valve.
May 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My kenmore side by side ice maker stopped working
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker. However, if you still get water through a dispenser (if you have one) then this cannot be the case.
May 26, 2010 | Whirlpool ED2FHEXN Side by Side...
Ice maker will not fill with water
May 26, 2010 | Whirlpool Refrigerators
Water not coming up to icemaker
May 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stop working
YES ... MOST PROBLEMS WITH ICE MAKERS THAT SUDDENLY STOP WORKING IS THE WATER SOLENOID STRAINER IS CLOGGED OR THE ORFICE INSIDE IS CLOGGD.(USUALLY LOCATED BEHIND THE FRIG. WHERE THE SMALL WATER LINE CONNECTS). THE STRAINER AND ORFICE IS USUALLY ON THE "INLET" SIDE OF THE VALVE.WITH BUCKET AND RAG NEAR-BY, TRACE THE SMALL WATER LINE AND LOOSEN EACH NUT TO SEE IF YOU HAVE WATER. SOME WATER SUPPLIES USE A SMALL "SADDLE VALVE" FOR TAPPING INTO A WATER LINE. THEY CAN CLOG TOO ... YOU CAN TEST TO SEE IF THE SOLENOID VALVE HAS POWER TO IT ... BY TAKING A METAL BUTTER KNIFE OR NAIL FILE AND HOLDING IT CLOSE TO THE TOP OF THE SOLENOID (coil) YOU SHOULD FEEL THE MAGNETIC PULL IF IT IS ENERGIZED. IF IT IS ENERGIZED AND YOU HAVE WATER ALL THE WAY INTO THE BACK OF THE FRIG ... THE PROBLEM LIES SOMEWHERE ELSE.
Apr 28, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
170 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
