Home Logo
A
Anonymous Posted on Aug 25, 2014
Identifying flying insects
3" t 4" length dragon fly body bee color with black stripes very thin black tail with wings
5 Related Answers
Anonymous
  • 1305 Answers
  • Posted on May 28, 2009
SOURCE: Fly wheel ring gear replacement
You need to pull the tranny out.
Then the flywheel needs to be unbolted from the engine.
if it's an automatic, purchase a new flywheel, if its a clutch, you can have a new ring gear pressed on to the flywheel...
Anonymous
  • Posted on May 30, 2009
SOURCE: no way to control a nice flying wing
I have two of my own. Its light and I guess its made to crash.I found the only to fly is to fly at night. so maby we will loose it.......
Anonymous
  • 4088 Answers
  • Posted on Sep 14, 2009
SOURCE: 97 Ford Power Stroke, starting problem.
Does the starter engage the drive gear with the action of a solenoid? It may not be pushing (pulling) the gear far enough. There may be a slipping ring gear on the flex-plate. If you pull the starter again, you can try to see if the ring moves in and out or appears to be slipping around on the flex-plate. The flex plate could be loose on the crankshaft. In any case, the engine or the transmission would have to come out. Check the starter engagement before removing the torus and flex-plate.
simontricket
Simon
  • 235 Answers
  • Posted on Oct 29, 2009
SOURCE: isuzu trooper 3 litre diesell oo year!
Set the engine on #1 tdc and the small half moon cut out  on the flywheel goes at 6 o'clock . The sensor is now set to read the crank angle .
This is for the manual gearbox ,if you got auto its at 12 o'clock.
Anonymous
  • 8197 Answers
  • Posted on Oct 30, 2009
SOURCE: I am looking for a Dragon Fly Tail Drive Shaft
http://www.gwsus.com/english/product/airfly/dragonfly.htm
The best place to get parts for your heli.
Good Luck
When we replaced our shingles we fouund under the shingles lots of round dics about 1 1/2 inch in diameter,with cotton like texture contained brown eggs an insect had laid.
It sounds that most likely it's a type of insect that makes and any insect that makes it cool cocoon will fly perhaps it is termite with wings
Flying insect
its called a dragon fly
What kind of bugs do praying mantis like best?
It feeds primarily on other insects such as fruit flies, crickets, beetles, moths and bees.
3helpful
My 9053 lifts off fine goes left right and reverse. but it goes reverse also when i want to go forward . Tail rotor turns at what appears proper rpm. and it changes direction when i push stick from reverse...
I own this heli also. The problem is that the tail rotor does not apply enough push to tilt the heli forward. It is this forward pitch that moves the heli forward. Aside form buying a stronger tail motor, upgrading your battery etc, the only thing you can do id this:
Get a credit card, a pair of scissors and some tape. Cut a couple of strips from the credit card about 2 1/2 - 3 times wider thhan the tail rotor blades and the same length. Now tape the strips to the top of the tail rotor blades. Make sure you don't increase the length.
This will help a little by providing more air push when the tail rotor in engaged. Without some serious modding, this heli will never be great.
I have more fun flying my micro size syma helicopter in the garage then I have flying my volitation. If there is even the slightest breeze, the volitation will float in the direction of the breeze and will not fly against it.
I cant seem to get replacement wings on my flytech dragon fly how?
I'm having the same problem. My 7 & 8 year olds boys got given one each and the wings broke when they were putting them together. wowwee.com sells them for about 15euros. I'm not paying that much, I'm sure the toys didn't cost that much! I think they're just an obsolete toy now. Have you had any luck?
2answers
Cutting cost on wing production, resulting in a nasty crash!
i normaly only repair large aircraft, but it seems your old good wing was fatigued from regular use and broke, and the new ones are of poor asian quality, thats why they are snaping. i assume the wings are folding up, so on the bottom attach a very thin wire (stainless lockwire if you can get) to the ends of the wing to fuse, at least 30 deg. from wing (like bottom of wing to bottom of fuse)
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
