Question about AMS Lutron SFSQ-LF Skylark Slide-to-Off Fan Speed Control and Single-Pole Light
I have recessed lighting in my living room with a dimmer i want install a fan with no lights on it
  • 3 Answers
Do you mean you want to replace your recessed with a fan with no light? Try to visit www.contemporarylightingdecor.com, they have lighting and fan experts who could give free advice.
Posted on Feb 17, 2010
How to fit dimmer switch
The dimmer switch you select will depend on the type of bulbs you will be using. The 'original type ' of dimmer works with regular incandescent bulbs and halogen bulbs only. They cost around $15.00. Then there are dimmers for compact florescent (cfl) bulbs and LED lights that are dimmable, as well for regular light bulbs. These types of dimmers are more expensive, ranging in price form around $40.00 upwards.
Light Switches Dimmers
If you are replacing a single pole switch ( just one switch that operates lights) you'll need a single pole dimmer. If you are replacing a 3-way switch ( two switches that operate the same light) you'll need a 3-way dimmer.
Installing the dimmer is pretty straight forward. All dimmers come with installation instructions. Make sure you turn off the circuit breaker for the particular switch you are replacing.
May 29, 2013 | Electrical Supplies
I wish to install a ceiling fan in my bedroom. The roughing is already installed in my ceiling. The problem is the electrical box is recessed a half inch into the ceiling. Could I mount the ceiling fan if...
a celing fan should only be mounted on a box rated for a ceiling fan. This is a NEC code requirement. You could remove your existing box, and install a new box rated for a ceiling fan. You install the adjustable cross bar, and then attach the box to it. It also has stronger threaded inserts for the fan attaching bolts. Better than having a fan flying through the room.
Jul 25, 2010 | Lamson Electrical Box Extender
Wiring Question
No, the way the motor speed control works is different from the way a light dims. If you connect it, it might work for a while, but it will either burn up the dimmer or the fan motor.
May 14, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
I have a problem with my kitchen's recessed lighting. For some reason, the six bulbs will go out during the evening hours, then come back on. There is no pattern, with one, two, three or four of them out...
It sounds as if you may have higher wattage bulbs and/or the wrong type of bulb installed in the can fixtures than the recessed cans are rated for.
When the wattage of the bulbs is higher than the rating of the fixture, and/or the wrong bulbs are being used, the recessed can's thermal overload device will shut off the light, to prevent damage and a possible fire situation.
It is unlikely that you've got a faulty dimmer, since you state that not all of the lights go off at once, thus it can be narrowed down to each can and thus the thermal overload being the culprit.
I would suggest you look inside the recessed can light fixture and determine what the maximum wattage bulb you can use, (60, 75, 90 watts, etc.) and use the next lower wattage bulb instead. I also install only Halogen bulbs in recessed cans, (they have a flat lens vs. a rounded bulb lens area like PAR type bulbs). Halogen bulbs are also the most efficient incandesent bulb that provides the whitest light possible and directs more light (and thus heat) downward away from the recessed can.
I avoid using a standard light bulb or PAR type bulbs in any recessed can fixtures as they tend to heat up quite a bit and cause the thermal protection to trip frequently.
As a Master Electrician that has installed literally thousands of recessed fixtures and dimmers, I can say that my customers prefer the Halogen light over standard bulbs and they last longer too.
I hope you find this Very Helpful and best regards!
Sep 17, 2009 | Lutron Diva Dv-600P Light Control By
Controller (s) not working
Someone used the pull chain on both units. Whenever you install a remote or wall-mounted dimmer, it's always best to cut the chains short (after setting the fan to high) to prevent someone who doesn't know any better from using them.
Download the installation sheets here:
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
May 15, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Light switch feels hot
If the switch is rated at 600 watts and you have six 100 watt lamps connected to the switch, you are at the capacity of the switch and heating would be expected. It's general practice to not place loads on a device that will exceed 80% of the device's ratings, in this case 480 watts.
Some heating in a dimmer switch is not unusual, but if it's hot, it should be replaced with a device with a higher rating or the loads should be divided. You could also lower the wattage of the lamps (to around 75 watt each) unless you would lose too much light.
If the sockets in the fixtures can be lowered closer to the surface of the fixture, you can probably reduce the wattage since more light will exit the fixture. You will also save a few bucks with less wattage. Lastly, check the fixtures themselves and see if they are rated for the wattage of the lamps you have in them.
Apr 14, 2009 | Lutron 1000-Watt Incandescent Dimmer...
Quit working
first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
Remote calibration
I installed three fans in the same room and one remote ran all three. In order to get the dimmers all to bring the lights up and down together, I changed the dip-switches in the fan housing so that the remote would only work one fan at a time. I then brought the dimmer lights all the way to bright. After all the lights were equally bright, I again altered the dip-switches so that all three and the remote were identical. The remote then dimmed all three lights equally.
Jun 16, 2007 | Hampton Bay AC438-VPW 52'' Vintage Pewter...
AMS Lutron SFSQ-LF Skylark Slide-to-Off Fan Speed Control and Single-Pole Light Logo
90 people viewed this question
Top AMS Electrical Supplies Experts
Craig Butler
Craig Butler
Mike
Gene Haynes
Are you an AMS Electrical Supply Expert? Answer questions, earn points and help others
