Question about Lexmark X5495 All-in-One &USB Cable/Ink/Paper/Software InkJet Printer
Each time I try to print from this printer any software that I am trying to print from unexpectedly quits and from then on, its hard to print from any printer. This was a problem that occurred quite quickly and I have never been able to fix the problem. Can you help?
  • Lexmark Master
  • 13,433 Answers
Hi
Lets try uninstalling the printer completely and then downloading the latest drivers and reinstalling it.
First open printers and faxes - Start - printers and faxes OR control panel -> printers and faxes.
Delete the printer from there.
Now uninstall the software for the printer - start -> control panel -> Add or remove programs or uninstall programs. Find the lexmark from the list and uninstall.
Unplug the printer from the computer. Restart the computer.
Download the latest drivers for your printer
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
Run the setup and install the printer, plug in the printer when asked.
The printer should work normally.
Posted on Jul 01, 2009
RASTERTOSEC QUIT UNEXPECTEDLY
This is usually related to the following:
  1. USB cable is damaged
  2. Software is not playing nicely with Samsung drivers
Replace the USB cable and see if the problem persists. In my case, it was only happening with MS Office 2011 on Mac. I update MS office and OS X (using software update). To update Office, open Word or Excel and click Help -> Check for Updates.
Once updated, try printing. If you still cannot print, try saving as a PDF through the print dialogue. Then print the PDF to the printer normally.
Go to System Preferences -> Printers -> Right click on printer and select "Reset Printing System"
There are some more technical things you can do to resolve this described here:
https://discussions.apple.com/thread/2162049?tstart=0
Sep 09, 2014 | Samsung Office Equipment & Supplies
I have an HP Photosmart Premium C3009 all-in-one printer. Sometimes it refuses to print with a message that says: The process stopped unexpectedly with status 1. I've looked in the manual and find no...
I also experienced the "process 'mdns' stopped unexpectedly with Status 1" message a few days ago with my new HP 7250, and found two solutions. Here are a couple of potential cures:
I downloaded the shareware program 'Printer Setup Repair', then ran their 'Reset and Backup' routine. Restarted, and bingo! Printing was successful. But trying to run either the HP scan software or the HP Ink Widget from Dashboard were not so successful. Got a 'Scanner not found' message. I then went to the printer, tried doing a manual scan there, sending the scan to my PowerBook. Once again, bingo. The scan was sent to my computer, and now the HP software could see the printer. I've since restarted both my computer and the printer several times; printing and scanning are working fine.
Now the second way to fix the problem. It's kind of hokey, but it seems to work, and is what led me to the The process 'mdns' stopped unexpectedly" with Status 1" problem in the first place. What you do is just add an ethernet router, that one you have lying around the house somewhere, between your DSL or cable modem and your Airport modem. Huh?
Here's the deal: when I first bought my HP multifunction printer, my wireless setup was this: Cable modem>Xsense ethernet router>Airport extreme. Unpacked and hooked up the HP printer, and it all worked immediately, perfectly. Print, scan, check supply levels, all no problem. Way too easy. Then, about a week ago I realized that the Xsense ethernet router that I had in the chain was really superfluous, as we no longer use ethernet in the house; might as well eliminate that unnecessary link in the chain. So I changed my setup to a simple: Cable modem>Airport extreme. At this point printing stopped. Tried everything I could think of, no go. Always got the "process ' mdns' stopped unexpectedly with Status 1" message. Put the ethernet router back in the chain, printing/scanning went perfectly. This made absolutely no sense to me, but it worked.
Left my setup with the extra router for a day or two until I remembered about the shareware program 'Printer Setup Repair', described above.
Before doing any of these steps it's probably a good idea to run Disk Permissions (I always run it before and after any installation), just to be sure you're authorized to be using the HP software.
May 04, 2009 | HP Office Equipment & Supplies
Cant scan with my Cannon PIXMA M470 anymore
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-9
Apr 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
During install message "trap monitor quit unexpectedly"
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Mar 19, 2009 | HP Photosmart C4280 Aio Printer
The printer Lexmark C532c is not printing.
Try using the PCL driver or select the "Disable Postscript Passthrough" under
Printing Preferences->Other Options->More Options->Postscript
Nov 12, 2008 | Lexmark T644 Laser Printer
HP 7210 All-in-One
Check all connections. I suspect a losely connected cable that generates greater interference when scanning...
Try to unplug and re-plug all connectors.
Feb 04, 2008 | HP Officejet 7210 All-In-One InkJet...
Unexpected Error (1001)
I have exactly the same problem, only my Deskjet is HP 3840 and I am running a PowerMac G4 with OS 10.4.10.
Dec 11, 2007 | HP DeskJet 5550 InkJet Printer
Lexmark X5495 All-in-One &USB Cable/Ink/Paper/Software InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
