Question about RCA P52926 52" Rear Projection Television
I need a lamp number for my RCA P56926 model TV. Can anyone help me??
  • May 11, 2010
    This set is a tube-type projection TV with three CRTs. It doesn't have a lamp. What exactly are you looking for?
  • 67 Answers
Bluestar international componets 1 800-522-2701 1-631-385-8171 or web site bulb 115.00
Posted on Aug 30, 2009
Tv wont turn on. flashes yellow twice over and over again
needs a new lamp.easy to relace youself.get the model number.go to ebay look up model number and lamp.get it with housing.cost about 50 dollors.thanks
Nov 20, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
P52926 52 in. Rear Projection Television: Hello. I am trying to find out what tube I need...
look on back of tv for make and model. get online and go tothe manuel of that brand look up parts and it should tell you
May 03, 2010 | Televison & Video
Crescent shaped image on screen - RCA 56" P56926
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | RCA P52926 52" Rear Projection Television
Powers on. green light flashes then turns back off.
For troubleshooting your lamp, use the following lamp troubleshooting wizard here:
http://www.fixyourdlp.com/wizard/launch-window.html
If it turns out you need a lamp, you can follow the simple instructions available here for just about any make and model, including your RCA. The RCA website is useless and they never have parts in stock.
http://guides.fixyourdlp.com/guides.php
Oct 09, 2008 | RCA HD52W58 52" TV
Replacement Lamp
If your model is the D52W19 you dont have a lamp you have three CRTs ( picture tubes) instead. What is the symptom? I have a good source for RCA parts. Please respond to this same post and if D52W19 isnt your correct model number please post that as well and I will assist you with your set.
Aug 04, 2008 | RCA D52W19 52" Rear Projection Television
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
RCA P56926 Would not turn off
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
Rca p56926 convergence problem
kraze3,
Your set has a repair issue with the convergence circuit.
Adjustments in the service menu will not help.............I agree
with Guest comment.... circuit board repair or replacement is
what you both need.....................T.
Nov 23, 2007 | RCA P52926 52" Rear Projection Television
Image problems
Dual image problem is generally a convergence issue.
A repair of replacement of convergence amp IC(s) and
possible fuse device in power supply will be needed.Ask a
local repair shop w/good reputation what the cost would be.
Oct 07, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
123 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
