Question about Samsung Office Equipment & Supplies
I have a ML-2010 Printer and I can't get it to print from my Macintosh Computer. What's wrong? It didn't always do this. How can I fix this problem? I really love this printer, it prints fast, and I need it to work so that I can print my eboks.
  • 583 Answers
Click the link below:
http://www.samsung.com/us/support/download/supportDown.do?group=&type=printersmultifunction&subtype=monochromelaserprinters&model_nm=ML-2010&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010400&disp_nm=ML-2010&model_cd=&menu=download
download latest drivers by selecting your operating system mac and reinstall new printer drivers and connect printer again to solve the issue.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jul 02, 2009
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
Samsung ML 2010 can't print in a certain format
you change office 2003 or its problem page setup
Aug 09, 2009 | Samsung ML 2010 Laser Printer
I have a Samsung ML-2010 mono laser not printing
Yes, you can make a self print test from the printer even if the printer is not connected to the computer. This means that the unit is in good working condition. Possibly your printer doesn't communicate with your computer. try this, hit start key>control panel>fax and printers>select your printer>right click to properties>click ports tab>check if the port is matched to the port you are using.also, make sure it is your default printer.
Jul 08, 2009 | Samsung ML-2510 Laser Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
PRINTER IS NOT WORKING
So, your saying you haven't installed the software? That would be the problem.
Copy and paste the following link into your address bar. Download the appropriate print driver. (save the file to your desktop). Run the installation program:
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=ML-2010R&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010400&disp_nm=ML-2010R&model_cd=ML-2010/XAA&menu=download
* please rate me ;)
Mar 17, 2009 | Samsung ML 2010 Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
How do I install my printer with out the disc?
u cant install a printer without any drivers u need them to send the spooler and other functions to the printer so it can work fine without any problems
go here and download the latest drivers install them than follow the driver instructions
http://www.samsung.com/uk/support/download/supportDown.do?group=print%20solutions&type=print%20solutions&subtype=mono%20printers&model_nm=ML-2010&disp_nm=ML-2010&language=&cate_type=all&dType=D&mType=DR&vType=L&prd_ia_cd=06010400
Jan 04, 2009 | Samsung ML 2010 Laser Printer
Can I print in Dos Programme with USB Printer
Assuming the printer can understand DOS coded printouts (which most should be able to), you can do it like this: Go to Control Panel | Printers | ML 2010 and share the printer. Then go to a command prompt Start | Run | type cmd Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type NET USE LPT2: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES at a command prompt. Now you can print to LPT2: and the output will go to the USB-connected printer. To find your computer name, right click on the My Computer icon (either on your desktop or the start menu) and choose properties. The window that opens will have a Computer Name tab.
Mar 22, 2006 | Samsung ML 2010 Laser Printer
23 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
