Trutech TV/DVD Combo can't get picture with digital signal
I have the Trutech PLV31199S1 and I was trying to get it connected now that we've switched over to digital but none of the rabbit ears I have work. I get a frozen, glitchy picture and not much or no audio. I wanted to make sure that this model does have a Digital Tuner, I'm assuming it does since I am getting some picture and when I look on the menu it says DTV Signal is bad, but I wanted to make sure. And I was wondering if anyone had any possible solutions.
sharcnet
  • 2130 Answers
SOURCE: Philips CCB130AT02 TV/VCR combo
Is this an Analog TV? Does it have a picture tube and not an LCD or plasma screen? Most likely this is a Analog TV.
If it is an Analog TV (and I would bet that it is), then no, it does not have a digital (QAM) tuner to pick up DTV broadcasts. The fact that it has a VCR also indicates that its an Analog TV.
If you are picking up your TV signals from an outside antenna and not cable, then yes, you will need a converter box to convert the new digital signals to Analog so that you can continue to use your TV set.
If you are using cable to receive your channels, the cable company already provides the conversion for you and your TV will continue to work as before.
The government is giving out coupons to help consumers defray the costs of purchaing a converter box. The following sites are good places to obtain more information.
www.ntia.doc.gov/dtvcoupon
www.DTVanswers.com
- Jim
Posted on Feb 06, 2008
clusterfx
  • 67 Answers
SOURCE: Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
manual
<A href="http://www.uwsp.edu/cps/facilities/classroom/manuals/VCR/PVD4752.PDF">http://www.uwsp.edu/cps/facilities/classroom/
manuals/VCR/PVD4752.PDF</a>
Posted on Feb 23, 2008
SOURCE: digital tuner
I don't have this unit, but guessing from it's description on Amazon.com, I'd figure that it is analog-only. So you would need a converter.
Here's the thing: all U.S. broadcasters are transmitting the new DTV signals NOW - in addition to the old analog signals. If a TV has a digital tuner, you should be able to use it now to see those DTV signals. Check your setup menu for options like ATSC.
One hint, the new signals use channel designations like 7.1 or 7-1 or 7-1HD. And some stations will have virtual channels, i.e., 7.1, 7.2, 7.3. If you can't get your TV to scan channels and show the numbers in that fashion, it isn't using a digital tuner.
Posted on Mar 03, 2008
ansilgregory
  • 4 Answers
SOURCE: My analog color TV,Sony 20S10, 14 years old, has
are there screw terminals that it connects too? if not but the wire is exposed like you said splice into it add in one of the transformers that has the rf end on the end of it. i would recomend some strain relief
ed
Posted on Mar 12, 2009
SOURCE: can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Posted on Mar 29, 2009
I need the code for programming a universal remote for TruTech 19" TV/DVD serial nunber PLV31199S1
Use code search to find something that can handle some or all functions of your TruTech TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Dec 29, 2016 | TruTech Televison & Video
Hook up to digital TV antenna indoor passive
Please check if the antennae is connected with right cable and the dipole is good. If so search the channels avaiilable and if there is no signal then it is possible that the TUNER is faulty. check using another TV with the same antennae or check the RF input using a VCR or TUNER.
Oct 30, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
Trutech tv - no sound, but have picture
Check if you would have the same if you use a different signal source. Another DVD Player, a playstation or other AV devices. The source or the TV may not be understanding each other, one may be sending analog signals while TV is only recognizing digital.
Oct 10, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Needs remote which remote is best for this unit
Any of the universal remotes should work.  Check their sites on line first to see if they have codes for your TV.  I recommend a Logitech Harmony remote that is "activity based" and can control all your electronics with a single remote.
Jun 02, 2009 | Audiovox PLV31199S1 19 in. LCD TV
Remote control switch destroyed
If you get an universal remote, you won't have all functions to control the TV. Moreover, the codes for many audiovox model are often not reported on universal remote manuals , therefore you may need to use autodetect feature on universal remote.
The best choice is buying a replacement original remote like the ones below:
New Original TruTech PLV31199S1 Remote Control
$39.95 -
New Original Trutech PLV31199S1 Remote Control $39.95
Apr 18, 2009 | Audiovox PLV31199S1 19 in. LCD TV
TRU TECH TV CODES
try code 10030 (comcast remote), or codes for daewoo.
Mar 28, 2008 | TruTech PLV16190 Television
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
