Question about Samsung HL-R4667W Rear Projection Television
Samsung television - HL-R5067W flickers green =DVR player
Green horizontal lines flicker when we try to use our DVR player (to play a movie). Started about two weeks ago. Any suggestions?
  • 50 Answers
If this doesnt happen on anything else you may have a bad cable somewhere or even worse a bad dvr. check cables first.
Posted on Aug 07, 2009
I have a Samsung DLP HL-R5067W that works great with HDMI as the source but flickers five lime green/purple vertical stripes when using the video/ audio input jacks. Thoughts?
those units have had problems with the siganl board and dm module both having solder connection problems and require to be sent out to a rebuilder that can handle that special work you might call samsung consumer and see if its uner and class actions or recalls
other wise it will be a local servicer to assist you further with its problems
Jun 05, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
My samsung R5067W DLP tv is showing green horizontal lines that flicker. If you unplug it and then plug it back in a picture will come on an stay for awhile and then the green flicker horizontal lines...
unfortunately your tv will require an expensive repair, digital and analog boards and possibly the dmd board. Julio milleniumtvsvc@gmail.com
Jul 25, 2009 | Televison & Video
Benq w5000 green horizontal line flickering at bottom of screen
Hi there
This is normally only one of two things : Cable or Mainboard
The W5000 is quite a new Projector and should still be under warranty.
But try changing the cabling first and if the problem still persists , let BenQ replace the Mainboard.
Aug 30, 2008 | Televison & Video
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
May 29, 2007 | Samsung HC-P4741W 47" Rear Projection...
Samsung HL-R4667W Rear Projection Television Logo
172 people viewed this question
Jerry Greenberg
Jerry Greenberg
