I have this deck that works fine but i have a cd stuck in there i push eject it wont come out but will keep playing if i let it i took face plate off and the metal piece after that to manually take it out but its stuck
SOURCE: JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
SOURCE: cd ejection
Look for a tiny, recessed Reset button on the front of the unit with the face removed. Press this button with a pen tip; it should spit out the CD and work correctly afterwards. This will also erase your station presets and audio settings.
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
SOURCE: Cd wont eject.
I was having the same issue with my KD-S5050. I also tried the CD eject lock reset with no results. By using the following steps I was able to reset my CD player and it is working properly again. On page two of the user manual is shows how to do a full reset of the cd receiver. While holding SEL (Select), press ATT (Standby/On Attenuator) for more than 2 seconds. This will reset the built-in microcomputer. http://www.fixya.com/Brands/J/JVC/Manuals/kd_s5050_cd_d2ce2654fa2aab37f3ad2b4ce1e33443/images/KD_S5050_CD_D2CE2654FA2AAB37F3AD2B4CE1E33443_2_p2.jpg NOTES: ? Your preset adjustments ? such as preset channels or sound adjustments ? will also be erased. ? If a CD is in the unit, it will eject when you reset the unit. Be careful not to drop the CD.
SOURCE: Cd is stuck
Disc Eject Prohibit: This feature keeps the disc from ejecting even if the eject button is pushed. The disc eject prohibit feature is engaged/disengaged by pressing the CD and Eject buttons simultaneously for more than 2 seconds.
