Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking/standby timer
It just started turning off at on it's own.model#kv-27v40 manufacture date sept.1998.blinks 4 times in a pattern.i've had it for about 6 months.great picture ,it won't turn back on. any help thank you
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Posted on Jul 15, 2009
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
I have a sony trinitron 27 in. model KV-27S45 1998 it will not turn on and the stand by timer is flasing 4 times dont know what to do
Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
Mar 25, 2011 | Sony KV-27S45 27" TV
Standby lighy blinks tv won't turn on
error code 4 is vertical deflecton failure . replace the vertical deflection ic. and the electrolytic capacitors in the vertical circuit. Or if you are lucky just resolder the vetical IC and resolder th horizontal section too.
Sep 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Won't turn on
Sony has self-diagnostics built-in to the TV. This is as you noted indicated by the blinking LED light(s). Initially and based on conventional TV sets, the four (4) blinks a vertical failure. This would normally mean the vertical IC requires replacement. In some Sony versions/models, the IC would be LA7835 but this has to be confirmed on the actual part from the PCB. There are instances where the IC is not defective but the diode and/or limiting resistor from the FBT that provides the ~+28VDC supply to the vertical IC that could be defective. As you will note, this is rather a technical repair and not an easy user action. This of course would require a familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Sony KV-27V40 27" TV
Trinitron suddenly turned itself off.Now doesn't go on.
Hi again,
I was just checking similar problems and saw that you posted twice.
Pls see your other post here with my proposed solution.
Nov 15, 2008 | Sony KV-27V40 27" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY Trinitron TV doesnt turn on
TWO Blinks
B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Nov 09, 2017 | Sony KV-27V40 27" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
960 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
