Blows the fuse right away after replacing. What could be wrong?
My first guess is the filter capacitors in the output stage of your amplifier are history/worn out.Try a different amp to confirm.Otherwise disconnect the speaker wires and check that the impedance/ohms value is at or near the stated value,4 or 8 ohms.This measurement can be made with a cheap ten dollar VOM "volt/ohm/meter."
SOURCE: JBL PSW-D112 Speaker fuse blow immediately after replaced
The Problem in this unit is the Amplifier module S64AMI,which is surrended in a black heatsink, filled with epoxy, not serviceable, the bad news is that JBL discontinued this module and is really hard to find, sorry....
