Question about Brother MFC-3240C All-In-One InkJet Printer
My printer wont print even after changing ink and cleaning
I have a Brother MFC 3220C and it will no longer print. I have replaced all the ink carthriges and the copies are still very vage and full of lines. I tried cleaning but that doesn't help either. HELP! PLEASE!!!
    Problem Solver:
  • 10 Answers
I have a brother MFC 3240C. My Black ink stopped printing, the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Posted on Feb 03, 2010
    President:
  • 2,306 Answers
When cleaning doesn't help, you need a new printhead. Around $89.00 now and then you add labor. They sell a new MFC 490 for around $120.00 with a year warranty.
Posted on Jul 02, 2009
~Brother MFC 3220c printing problem-o!~
clean the print head with water on a rag. it could need new cartridges also.
Sep 26, 2012 | Brother MFC 3220C All-In-One InkJet...
How to change ink?
Press print button. Choose replace ink. Ignore this two steps if the display on your printer is Colour Ink is Empty.
Open cover. Press the round side of the ink cartridge holder arm and the holder will pop up. Take out the ink cartridge. Put in the new cartridge and pop the holder arm back by pressing it down.
Remember to remove the seal below the new ink cartridge before replacing it.
Jun 10, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
My printer has an error #41 on the screen what
THE ERROR 41 INDICATES AN INCORRECT VOLTAGE COMMING FROM THE PRINTHEAD, THE PRINTHEAD WILL NEED TO BE REPLACED AND THE HEAD I.D. WILL NEED TO BE RESET, ALSO, BROTHER RECOMENDS THAT YOU CHANGE ALL OF THE INKS TO NEW INKS. THE RESETING OF THE HEAD I.D. CAN ONLY BE PREFORMED BY AN ATHORIZED BROTHER SERVICE CENTER. THIS REPAIR CAN NOT BE PREFORMED BY THE END USER. I HOPE THIS HELPS.
Apr 11, 2010 | Brother MFC 3220C All-In-One InkJet...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Brother MFC-3220C, the black ink cartridge is jammed in the print carriage. It's not printing and I wanted to take it out to clean and I cant get the release to let go so I can take the black cartridge...
Try releasing the two metal clips by the side that hold the print head. Take out print head partly and try removing the black cartridge again. Hope this help
Mar 27, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Print head for brother mfc-3220c
how do you remove the ink cartridge from mfc-3220c when the lever is stucki
May 18, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/48446421@N05/sets/72157623635891898/
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-3220C
Error 41 is Print head needs to be replaced, on this model it is not a big job, Heads can be purchased from Brother dealers, ring brother to locate if you wish to repair this machine rather than replace it.
Head sells for about $80 for the part from a brother dealer 1-800-284-4329 and it will need a new set of inks too, not really worth it just replace with new machine with ink and a warranty.
Very common issue, brother extended warranty for this fault for two years but yours would be past it by now, the s/n tells of build date, the first two digits of the LAST NINE of the serial number indicate build date, so a K6J702822 ending serial no. means it was built K6 = Nov 06.
I beleive that this is a result a lot of the time by the use of refills and remanufactured ink cartridges being used.
There is heaps of info on net regarding "error 41".
Nov 15, 2007 | Brother MFC 3220C All-In-One InkJet...
Printing
went printhead is replaced, all old ink should be cleaned out and replace with OEM ink only, Generic and refills help in damageing the printhead.
Dec 20, 2006 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-3240C All-In-One InkJet Printer Logo
803 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
