SOURCE: Can the Magic Wand Rechargeable Massager be
If your wand is N American then "don't do it" 220 through a 110/120 will fry all the magic out of it. You could get a step down transformer 220 to 110. Plug that into the 220 socket and plug your magic wand charger into that.
The cost would not be worth it though ... buy some more magic that is 220. be happy ... not sorry :-)
SOURCE: the small spring inside my
Hello there, Hitachi does not provide support for this product parts wise.To get a replacement spring you would need to get the spring from the nearest hardware store available to you. Basically what you need to do is determine the size of the spring and you can easily get a replacement spring from the nearest hardware store. Usually it is recommended you take the unit there so you can get the exact size needed. Other than this you can get the spring size and order a replacement spring online from amazon or ebay or any hardware website in your locality.
Hope this support has been helpful?
Thank you for visiting FixYa.
SOURCE: I fixed my hitachi magic
rotate the head/neck part, one of the sides is not aligned with the notches in the bace of the neck. rotate it to fit right then you should be able to fit it on easily
