Question about Emerson MW8779W Microwave Oven
Microwave went blank when I hit defrost... not working; no even clock.
Emerson MW8779W YR2000- I use this all the time. Tonight the clock was on per usual when I went to defrost something, which I hardly ever do... I just "cook". The microwave just "died", nada, all blank. The outlet is working as I did check. I had no warning so is it a fuse/fixable? I loved this unit as it has worked fine almost daily since I purchased it yrs ago. If I need to buy another, I have seen reviews that are not saying good things about this model... many report a similar issue. I am in an apt. & I need one that does not take more power as a fuse will blow. I can not seem to find the amp. usage. Can you tell me that by any chance? I do not know if all 800 watt microwaves draw the same amount of power. I do not want to purchase one that is heavier on the juice... any suggestions would be greatly appreciated!
  • JLAK22 Jan 10, 2009
    I had the same thing happen to mine which is the same model; put something in it and pressed start and everything went blank; clock and all buttons are dark and nothing will work. it is not my outlet. my question is is it resonable to try and find someone to fix it and what should it cost to fix ? or is it done for, a land fill additive and should i begin shopping for another one? the tag says it was manufactured in 2000 but it is in pristine condition and i hate to dump it if it can be fixed easily for a reasonable cost. thanks for the help and advice. JLAK.
  • Emerson Master
  • 9,098 Answers
This will probably use a 15A ceramic fuse and will draw about 13 amps when running.
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again. This may mean you'll need a new magnetron.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
Emerson manual guide microwave model Mw8779w
Here is a link to a website where it looks like you can download a pdf of this manual.
Jan 12, 2014 | Emerson MW8168B Microwave Oven
Where can I find a replacement tray for an Emerson microwave MW8779W?
I've checked the places where I normally get parts, and also checked online. It looks like the manufacturer no longer supplies the original part. This means you either need to replace the oven, or see if a suitable tray for another oven might be available. This site is often mentioned as a good place to check, although I've never tried them myself. You could also check for appliance service shops or parts stores in your area that might be able to supply a generic tray that might work.
Good luck on your search and thanks for using Fixya!
Jun 01, 2011 | Emerson MW8779W Microwave Oven
Kenmore microwave giass tray #5668842580 Sears says they dont make them annymore.
Try here:
Jan 27, 2011 | Emerson MW8779W Microwave Oven
How to use the defrost section, poultry, meat, fish?
Usually after selecting poultry,meat etc the weight must be added in.
Have a look at the instruction book online and download a copy at the manufacturers web site.
Hope that helps.
Nov 23, 2010 | Emerson MW8779W Microwave Oven
When pushed, the 30 sec button says 3 minutes. none of the display buttons work.
Have you inadvertently programmed your microwave for "autostart"?
Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
Have you tried unplugging it for a few minutes?
This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
Dec 26, 2009 | Emerson MW8107WA Microwave Oven
Plastic foot. I'm missing one out of four. Emerson Model MW8779W. Need one. Can you help?
Sadly, no. You may find a similar one at Lowe's/HomeDepot/similar, or you may want to remove the other three and replace all of them with the same type. Would those stick-on felt dots work for you?
Regards, --W/D--
Aug 01, 2009 | Emerson Microwave Ovens
Need a replacement Turntable Supports / Wheels
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
May 25, 2009 | Emerson MW8779W Microwave Oven
I'm looking for a microwave tray for an Emerson - Model: mw8115ss.
That part number is 252200200010 and the best place to order it is Tritronics.
You can also call them at 866-779-5835.
Nov 25, 2008 | Emerson MW8779W Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
Emerson MW8779W Microwave Oven Logo
173 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
