Question about Coleman Mach III Air Conditioner
Have a coleman mach iii also, worked the weekend before this past weekend however nothing at all turns on, fans move freely and there seems to be some sort of click when it is suppose to kick on...anything i can do myself?? thanks for any and all help.
  • 614 Answers
The click you might be the compressor trying to start. Could be a capacitor. But it looks like your comp. is trying to start. You need a service rech to check this out. There is only so much you can do. Rus
Posted on Jul 01, 2009
High speed
high speed relay or bad fan motor.
May 26, 2014 | Coleman Mach III Air Conditioner
Coleman 2ton Basement air does not respond to thermostat but will turn on and run fine after 6 to 36 hours
Check contactor in condensor,if it looks good check refrigerant levels if you're EPA liscensed.
May 25, 2014 | Coleman Mach III Air Conditioner
Coleman Mach III RV AC
Sounds like possible fan capacitor failure. If your not familiar with capacitors, please find someone who is, as they can give a fatal electrical jolt if not handled properly.
Jan 26, 2013 | Coleman Mach III Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
I have a Mach III. Unit blows hot air and bogs down when cooling.
probably (90 %) the compressor's bad, depnding on the repair cost you probbly want to just get another AC unit
Aug 30, 2009 | Coleman Mach III Air Conditioner
I have a 13,500 btu coleman on our 1989 avion camper. It was making a very loud noise for some time, and vibrating then the motor locked up on it. My husband thinks the blower went out on it. It was...
You should be able to turn the fan motor freely by hand. If there is any resistance or the noise turning it by hand, then the fan motor is definitely bad. Is it a wall thermostat unit or manual controls? Wall thermostat, you can use a jumper wire from the 12+ terminal of the thermostat to the HG terminal and the fan should come on, if not, then the motor is bad.
Jun 24, 2009 | Coleman Mach III Air Conditioner
Compresor starts but fan just buzzes.
No , is their power to the motor? could be bad motor or capacitor?
Jun 16, 2009 | Coleman Mach III Air Conditioner
Coleman Mach III Air Conditioner Logo
152 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
