Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Mower starts but boggs down and then dies
My lawn boy ran fine i loaned it out and this is what i got back
  • 413 Answers
Sounds like the air filter media is full of muck.
You need to clean it.
Everything should then be fine....
Posted on Jul 02, 2009
My 2011 Ford Escape boggs down then dies
if the engine light is still on take somewhere and find out what the problem is
Mar 02, 2014 | 2011 Ford Escape
Lawn mower starts then dies
sounds like ur timing gears have jumped a cog or two. That's the gears at the crankshaft to the camshaft. Pretty big job if you don't know what you are doing.
Apr 24, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lawnboy 6.5 b and s motor was backfiring loudly when trying to start now when engine runs and heats up it cuts out and will not restart any ideas??? ran fine for a year and a half.
you need a valve job and have a unseated intake valve might have to get new motor if cant seat valve have to take to shop if cost 3rd by new mower
May 15, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Sep 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My throttle position markings have worn off. Is start position to the front or rear? It cranks in both but quickly dies.
Usually if you push the lever forward that is the start position (or choke position) once started in this position from cold start, slide back this should be fast, slide a little further back and this should be slow then all the back should stop. Have not worked on a lawn boy silver for about two years now but all are about the same, anyhow give that a go, good luck!
Oct 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Can't get my lawn boy started
check for a faulty wire to the engine kill switch it may be contacting the ground
Jun 22, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
The mower is a cub cadet it usually runs fine until warm and will die start idling up and down and then die every now and then pop like back firing.it will start right back if you lift the choke i changed...
I had the same problem , found out it was the coil was getting hot. I replaced the coil which was not hard , remove 2 screws an unhook 2 wires. You have to get the coil from a dealer , in my area anyway. Hope this helped.
Apr 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
857 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
