Question about Garden
Pullcord on my Craftsman 6.0 lawnmower does not pull, seems to get stuck before engine turns over. Took top cover off to see if there was an obstruction, did not see one. Is this something I can attempt to fix?
  • 68 Answers
It's likely the rope came off the pulley and is lodged in behind it. They usually can be fixed by bending back some tabs or taking out a bolt to let the pulley come out a LITTLE. Be carefull because the rewind spring behind it will unlatch if you pull too far. It's not that strong but it will whip around and it has a sharp end
Posted on Jul 04, 2009
Brand new snowblower. Engine will not start
Stuck? you mean if you try to use the pull starter the engine will not let you pull the cord out?
Will it not start OR is the engine frozen. help us with your description
Take the Spark Plug out and see if that helps it turn over. Maybe the float in the Carburetor is stuck open and the cylinder filled with gas Causing Hydrolock.
Dec 19, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Lawnmower problems
Remove about 5 small bolts holding the recoil cover on
Sep 07, 2014 | Garden
Craftsman lt1000 stuck in neutral
The rear wheels are keyed to the axle shafts with a sqaure key, if the last owner forgot to replace one of the keys the axle will just turn in the centre of the wheel and not turn it, because the gearbox has a diff it means neither wheel will turn if either side has the square key missing, pull the wheels off and check the key is there.
Jul 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman Series 550 Lawnmower was working fine and I decided to check and clean the airfilter and carburetor. When I tried to restart the pull cord is stuck and won't allow me to pull it. I have...
i suggest you pull the housing off for the pull cord and see if it pulling fine if it does see if the brake is of on the motor i would bet the brake is not releasing
Jul 17, 2017 | Craftsman Garden
I am trying to find out how to replace the mower belt of my 2006 LT2000 23hp Craftsman lawnmower
Replacing the belt is easiest if you drop the deck. There are roughly 6 pins you must pull (refer to sticker on deck) including the engagement cable. Pull the deck from under the tractor and remove the plastic pulley shield from the left side. Remove the belt and replace the same as you took off and re-attach the deck to the mower.
May 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Shrieking Lawnmower!! I hit small tree branch w/ walking non-drive 3.75 hp Briggs and Scrap-Iron "Sprint" off-brand gas mower. Started shrieking like banshee. Resulted in tangled pull-cord. So I removed...
sounds like you have dirt in the recoil clutch, (under the screen) or you bent something there. try removing the clutch and make sure shaft is very clean and lightly coated with oil. This would be for a briggs and stratton engine.
Jul 25, 2009 | Garden
Craftsman DT4000 Running loudly
believe i had same problem this is what i did i took took the head cover under the carb and my needles was bent had to replace them now it works great again
May 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Pullcord violently retracting on Craftsman lawnmower
It is possible that the 'dogs' that engage the crankhaft were stuck in the out (engaged position). Once the engine started, it wound the rope in the opposite direction until the dogs slipped and retracted. Romve the top cover that includes the pull start unit. Check for smooth and sticky free operation while pulling on the cord. Try using a very light oil to lube if nessesary.
Apr 29, 2009 | Sport & Outdoor - Others
Pull cord stuck
it sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
Apr 18, 2009 | Mantis 2-Cycle Tiller
Husqvarna model 700DRT the rope pull is stuck
usually three/four bolts hold the recoil housing on the engine. two on top two on either side of bottom. let me know if im wrong i have other answers
Apr 08, 2009 | Mantis 2-Cycle Tiller
Garden Logo
488 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
