I believe you must first remove the plastic cover that is snapped over the cylinder heads. Once removed the plugs are easily accessable.
1) Remove the plastic engine cover. It snaps off.
2) At that point the plugs should be visible. One plug at a time: Remove the spark plug wire, remove the old plug and install the new properly gapped plug, reattach the plug wire. Repeat the process for all the plugs.
3) Replace the plastic engine cover.
