Window doesn't recognize any device such as the web cam,mouse,printer . it was work before
  • 197 Answers
Try to update your machine's bios to its latest version then restart your machine. if it still doesn't work then try to re-intall devices of your machine such as web cam, mouse and printer.
Posted on Jul 02, 2009
My acer laptop camera is not working... when i open webcam it doesn't open and said camera not found...
goes to equipment and push right click of mouse, choose propierties and goes to devices administrator, look for image devices and see if the cam is there. If not goes to acer web site and re-install the cam driver. good luck.
Jul 29, 2011 | Acer Aspire 5610-4648 Notebook
How do I setup my wireless mouse and keyboard
Need more information but normally you would hook up the infrared device or usb device to the laptop. Then you would make sure that the keyboard and mouse has new batteries in it. At that point windows should recognize the mouse and keyboard. You may have to push on the connect buttons on the keyboad or mouse to get the laptop to recognize them.
Other then that its not really hard. Just time consuming if it doesn't take right away. Most of the time you don't need software installed unless the manual tells you to install them because windows will recognize them.
May 29, 2011 | Acer Aspire Z5600 PC Desktop
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
EZonics Web Cam not working for User
Try downloading another driver. You can find the download here:
http://www.topshareware.com/web-cam-ezonic-ez-cam-usb-driver/downloads/1.htm
Oct 05, 2009 | Ezonics EZCam Webcam
Icontact web cam will not turn on
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 11, 2009 | Ezonics iContact Webcam
USB devices (not recognized)
Hi Hanna,
You may try to uninstall and reinstall the driver of your webcam. You may need to check also if the driver application is compatible with the operating you are using. Most of the new system we have now are operating in 2.0 USB port drivers.
If your webcam driver is compatible only with windows XP, then it won't help you resolve the problem if your system is operating in Windows Vista (new operating system for most new system).
Please clarify also the type and model of the webcam you are using. keep me posted.
Thanks.
Oct 11, 2008 | HP Compaq nx6110 Notebook
Malfunctioning webcam
What you need to do is update your usb drivers. Follow instrution below.
Firstly re-insert your web cam.
USB driver update in
WindowsXP
061027085005_16154.png Click Start -> Control Panel -> System
061027085005_16154.png Click the tab Hardware and then click on Device manager
061027085005_16154.png Click at the bottom of the tree on the + sign before Universal Serial Bus controllers
061027085005_16154.png Select the first entry, right mouse click and click on Update driver...
If your are using windows 2000 use the one below
WindowsXP
061027085005_16154.png Click on the tab Driver and click on the button Update Driver.
061027085005_16154.png Follow the steps to update the USB driver
Feb 09, 2008 | Philips SPC610NC Webcam
Computers & Internet Logo
Alun Cox
David Payne
David Payne
