Question about Xerox WorkCentre Pro 580 Plain Paper Laser Fax
My plain paper will not feed to print incoming fax????
    President:
  • 2,072 Answers
If it is a WCP 580. clean the feed tire very well with something like formula 4009 then rinse it with alcohol.
Most likely that feed roller is cracked and worn. Will need replaced.
Posted on Jul 02, 2009
I get plain paper or double when I received fax from my uf5300 laser fax.it print one page from 5 pages that sent and I got empty pages and double somtimes
Paper feed rollers and sheet feed pad dirty. Feed roller on top pad should be just below. Clean with alcohol. Papers have clay in them. Recycled is worst. It will glaze the pick up roller and pad.
Sep 21, 2014 | Panasonic PanaFax UF-8000 Laser Fax
Not receiving incoming Fax
is the number for incoming fax correct and setup properley
Sep 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
The copy/receiving function will not work.
hi,clean feed roll if the feed roll out of use please replace it.
May 14, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Info Code 54
Code 54 is a BAD LASER UNIT
try this:
Open the toner door
press function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for reboot
Jan 28, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Incoming faxes do not show time or date
function-7-4-start-9-start-2-start-stop
this should print the time and date on the paper
Jan 22, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Printing of incoming faxes
I have the same problem on my hp all-in-one. it looks like a staple went through the copier and it shows on incoming faxes as well...
May 21, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
How to Clear Memory in Sharp Fax UX P115
call sharp tech support (905 568 7140) for instr. they are very helpful and will guide you thro' the deleting memory process in madel ux-p115.
thanks
lk
Apr 11, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
Paper feed
Is your paper right in slot with grey flap over top of paper feeding into slot.
Apr 08, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
Mar 21, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Xerox WorkCentre Pro 580 Plain Paper Laser Fax Logo
106 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
