Question about Dryers
I have a Lasko portable fan with wind tunnel remote switching it has a printed circuit board Model of fan is 3440
  • 508 Answers
Whats wrong?
Posted on Jul 01, 2009
How do i remove the actual blade unit from the backing on my lasko wind tunnel remote?
the blades are held on with a left handed thread for the center
undo tat by turning it clockwise and then the blades will slide off the shaft
Nov 04, 2017 | Lasko 20" Stylish Wind Tunnel High...
My Lasko 42" Wind Curve fan when I plug it don't power up. Pluged at diferents outlets, same results Thank you
Check out the cord, (frayed or broken) usually right where it enters the unit, and the switch.... if these check out then the motor has gone bad...
heatman101
Aug 18, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
I just came from Trinidad and they use 110 volts and I'm now back in my island where they use 240 volts and not knowing too much about this stuff i plugged in my lasko fan using and adapter and the motor...
Unfortunately, probably not. The motor would only be designed to handle 110v, and it would burn up with 240v applied. You can take it apart and inspect it, hoping maybe for a bad switch, but chances are the motor is, as you say, blown. Sorry to have to relay the bad news.
Jun 03, 2010 | Lasko 3440 Wind Tunnel Floor / Box Fan
Where can I find a motor for a lasko FAN model 2554C. Motore number is Decomin 2033014 120V 0.45A Thanks
call up the comp! or if you brought it less than a year they have to replace it the catch is the recipt!
May 09, 2009 | Lasko 2554 42" Wind Curve Fan with remote...
Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
Mar 30, 2009 | Lasko 3440 Wind Tunnel Floor / Box Fan
How To Clean
On the back of the fan there are 6 recessed phillips head screws around the circumfrence of the fan. You must use a longer screwdriver as the screws are set in a couple of inches.
The two screws on the bottom are a little harder to see.
There are also two clips on the sides front cover. Squeeze on the sides gently to release these.
Jun 28, 2008 | Lasko 3440 Wind Tunnel Floor / Box Fan
Fan seems to go and stop and then go again is this normal o
I have one of these. It sounds like you have it on breeze (the 3 wavy lines on the remote) Push that button, then push the run button(first button on the right bottom) for it to run normally. The circle with the blades in the middle(left button on bottom row) will turn the fan from low (1) to (3) high. The icons are the same on the remote and the fan itself. Hope this helps.
Jun 14, 2008 | Lasko 3440 Wind Tunnel Floor / Box Fan
Dryers Logo
95 people viewed this question
Top Dryers Experts
