Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
THE ICE MAKER IS NOT WORKING. I emptied the Ice bin for a party and now the Ice maker will not make new cubes. The water line is fine and I still can get water.
  • 4,070 Answers
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Jul 01, 2009
Ice maker is not making ice. what could be the problem?
The two most common things that happen: the ice piles up too high, which pushes up the bar that tells it the bin is full and stop making ice. OR the ice sticks to the ice cube maker. If the ice pile is too high, knock it down or empty the bin. If the ice is sticking to the cube maker, try melting it and then spraying it with a non stick spray. Sometimes the water supply line is clogged, but that is not usually the problem.
Feb 28, 2015 | Refrigerators
Tip
Ice maker stopped working
When the ice bin fills up, it won't let the arm all the way down. The arm must go down for more ice to drop into bin. Sometimes an ice cube or two will get caught under the arm and prevent it from cycling. Continuing to use the ice maker will empty bin but no new ice is made. Clear any ice cubes from under the arm and the cycle will start again. My ice maker takes about twelve hours to fill after it has been emptied but ice from the door is available almost imediately.
on Aug 23, 2010 | Refrigerators
Why is my Viking freezer not making ice?
I would suspect that the sensor used to measure if the bin is faulty. They usually use a small probe or a magnet on the ice maker door, if one is dirty or the door is not closed properley the machine may think the bin is full and decide not to make ice. I would look for a sticking door or dirty probe.
Sep 07, 2012 | Viking Refrigerators
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
The Side by Side GE Profile refrigerator does not dispense any water or ice. It worked for a short period of time but just stopped working. Also, all the options that are suppose to be lite go off when the...
Could be several problems (I'm a homeowner, not an expert). GE had a problem with the water line in the freezer door: not enuf insulation so the line freezes, hence no water flow. I would look at this first, especially if you press the water dispenser handle and you hear the pump, but no water comes out. Ditto if the ice bin is empty or the ice maker isn't making any more ice. If the icemaker is making ice but not dispensing it, then the auger (thing that agitates the ice cubes in the bin) may be broken or frozen. (if frozen be sure ice cubes in bin are loose and not frozen into one big ice cube).
Aug 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Ice maker will not eject ice cubes in GE Profile gss25tswass
Empty all ice from the bin and from the "Drill" like Ice shaper spinning unit. Let the unit make some new ice and see if that works.
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Jun 22, 2008 | U-Line Icemaker
Ice cubes
enoty and wash out the ice bin with hot water and let air dry, before you reinstall the ice bin
Be sure to turn off the ice maker so it will not make ice while the ben is out of the ref
Apr 15, 2008 | Whirlpool ED5SHAXM Side by Side...
ICE MAKER AND WATER SUPPLY DOES NOT WORK
I lifted the switch to turn ice maker off, left it like that for a couple of hours, then turned it back on. I checked it a couple of hours later....Making ice now....
Thanks pete5runner!!!
Feb 18, 2008 | Refrigerators
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
397 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
