Question about Microsoft Network Programming for .Net Framework (0-7356-1959-x) for PC
.net framework installed?
Microsoft program to check if your pc is compatible with Windoes 7 requires specific version of .net framework. How can I tell if I have .net framework installed and which version?
  • 81 Answers
You can check by going to the Add/Remove programs within the control panel or it is called Programs in Vista.
Posted on Jul 02, 2009
How to install Print Master Platinum 17 on windows 10
You can't!
Unfortunately this program is not supported on Microsoft's new operating system Windows 10 as it requires .Net Framework 1.1. There are currently no updates available as Microsoft is no longer supporting .Net Framework 1.1.
So if it says anywhere in the instructions "requires Net Framework 1.1" then it won't run. It was compatible with Windows 7.
Oct 19, 2016 | Computers & Internet
Lexmark productivity studio
Hi, in Windows 7 Microsoft.net framework 3 is installed and newer versions can be installed on it. If you try to install an older version, it will block your installation.
1-Try to download it from Microsoft\'s website and install it with administrator account privilege.
2-Go to the control panel, find out if Windows features are on or off. Try to check
Microsoft.net framework and then restart Windows. Then reinstall it.
3-If you have still problems, go to www.microsoft.com and search microsoft dot net framework 2 in windows 7.
kind regards
Apr 17, 2013 | Office Equipment & Supplies
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
I want to download Microsoft Net. Framework 2 x86
Access: http://WindowsUpdate.Microsoft.com
Click "Custom Search"
When it completes, click "Optional Software" (on the left).
Click to select the latest version (version 4) of the Net Framework, not Version 2 -- any software that requires Version 2 will be compatible with Version 4.
Install it.
Restart your computer, when prompted.
Oct 21, 2010 | Computers & Internet
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
May 28, 2010 | Microsoft Windows Vista Ultimate Edition
I have windows 7, and I connected my printer. My problem is that when I click on the lenmark icon on my desk top I get a pop up box that says that says required system software not installed, Microsoft...
Only the software listed for Windows 7 should be installed so install the Windows 7 version of .net framework. It actually sounds like an update rather then the entire piece of software.. You should be fine installing this..
Dec 07, 2009 | Office Equipment & Supplies
I have windows7, the printer that I have is the
u need dot.net framework of Microsoft for any applictions that use the network service of the PC.
download the latest version. Check/download 3.5 SP1 version.
http://msdn.microsoft.com/en-us/netframework/default.aspx
Dec 07, 2009 | Computers & Internet
Print Shop 23 appears to install, but never finalizes
The fact that MS Net 1.1 framework is compatible with the 32-bit version of Vista - because I am using Print Shop 23 on my 32-bit version of Vista.
However, Print Shop 23 is not supported on the 64-bit version of Vista. and MS Net 1.1 framework is not compatible with the 64-bit version of Vista. So, I would guess that you are using a 64-bit version of Vista.
I have heard that one way to work around compatibility issues with MS Net 1.1 framework is to make sure you have the latest update installed for MS Net 1.1 framework. But, since I'm not sure that that is the only recommended fix for your problem, the best thing for you to do would probably be to click on this link
http://forums.encoreusa.com/tm.asp?m=24071&mpage=1&key=%E5%B8%87
To find quick answers to Frequently Asked Questions about Encore and Broderbund products, please visit Broderbund's new Product Support web site at:
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
Jun 13, 2009 | Microsoft Windows? Vista Home Premium...
Microsoft .NET Framework 1.1
You cannot install the Microsoft .NET Framework 1.1 because the NET Framework 2 is already installed. The NET Framework 2 is the latest version of Microsoft NET Framework. I think you can remove the latest Framework in the Add/Remove Programs from the Control Panel. Then restart your computer and install the old version. But my advice is, just let the latest NET Framework remain and don't uninstall it.
Jun 02, 2008 | Computers & Internet
Microsoft Network Programming for .Net Framework (0-7356-1959-x) for PC Logo
141 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
