Canon PowerShot SD1100 IS Digital Camera Logo
Posted on Jul 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Focus not working
The focus on the camera not working. pictures taken are very blurry and when trying to reset ...it says "busy"
Anonymous
Level 2:
  • Expert 126 Answers
  • Posted on Jul 02, 2009
Anonymous
Expert
Level 2:
Answers
126
Questions
0
Helped
36285
Points
249
You have a bad lens, not worth repairing. Look to sell as is on Ebay for parts value. The screen and other parts can be salvaged.
Out of focus pictures when shot with view finder
I had a problem similar to this. Try taking off your glasses or removing your contacts and try again. Best of luck.
My Cannon Rebel XSi when pictures are taken are blurry
Try using manual focus. Make sure your auto focus points are correctly set. Look for button that looks like matrix. Press it then use/press joy stick type button to select auto focus point.
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
1helpful
My pictures are coming out blurry and i didnt drop it or anything
Make sure that the camera is set to auto-focus. It is possible that the camera was put on manual focus and now each picture is taken out of focus resulting in blurry pictures. This setting shuld be found in the menu settings or on the back of the camera. Check in the menu options first. Let me know if this does not work. Thanks!
Pictures are out of focus on screen and when taken i cant seem to reajust the focus camera has been working fine untill i went to take a close up shot and now completely blurry .
If you are focusing On a subject make sure first that you are two feet away,
You can also try to turn On the blur reduction under setup menu. make sure also that your on auto mode or smart scene.
when taking picture indoor turn of the flash, you can do this by pressing the flash button On the camera
here are some basic troubleshooting
try to put your camera On a tripod or on the table to stabilize the camera then try to take a picture.
the technique of taking a picture Is first you need to half press first on the shutter button and you will noticed camera will adjust Now if the camera already adjusted pull press on the shutter button.
Blurry picture may caused if camera is not stabilized and may cause also if the flash will not fire correctly.
you may call tech support for further support toll free 1 800 235 6325
1helpful
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
Blurry images on camera
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
2answers
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Blurry pictures
First try resetting camera to factory defaults.
Press menu
go to setup
go up to reset
press right arrow, highlight reset again
press set.
If that doesn't work then make sure you are pressing shutter half way down and allowing time to focus.
Still not working? Then you will have to send into repairs.
Blurry Vision
What are you looking at on the screen? Before or after the shot? The this point the taking sequence-point camera at scene look in screen blurry image - half press the release - autofocus comes into play- press all the way picture takes.Sharp picture in the taken images what are you doing?
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
