Question about XG Viper 2 ATX Mid-tower Gaming Case w/Acrylic Window Blue LED & 500W Power Supply - Silver (ET-CAV2-SL) ATX Mid-Tower Case
LCD display on case not working.
Hello, I recently got a Viper 2, gaming case, and the LCD display on the front, seems to only want to display the same numbers, no matter what.
It says,
Fan 1 - 8880
Fan 2 - 8880
Fan 3 - 8880
Work time - 88:88
CPU - 188
Lots of 8's, eh? Well, looked inside, and all the wires are plugged in, so not sure why it's having this issue. Thanks for the help.
  • Anonymous Nov 11, 2007
    I have the exact same issue. Please post up some solution. All seems connected, and I don't love the idea of rooting around on my MB on a new machine anyway. Ibuypower.com has been predictably useless.
I have one of these cases also. The LCD was covered with a piece of plastic that had fake numbers and whatnot. I had to work at the edge to get a corner up, then once removed all is well.
Posted on Jan 06, 2008
    Genius:
  • 1,601 Answers
Did you try to reset the LCD?
Hit + - at the same time.
If that dont work contact manufacturer for replacement.
Posted on Nov 16, 2007
  • Thomas Christopher
    Thomas Christopher Nov 16, 2007
    or try this:
    The numbers you see are NOT because the unit it lit--it is because they are BACKLIT from the fan lights. The power on the LCD is not on.
    You need to open the case and make sure that the the PWR LED is connected on the motherboard--should be two wires. Make sure it's connected. If that does not solve it, just reverse the two wires; ie take it off flip it 180 degrees and put it back in.
Where does the black wire on the valet switch for a older model viper 300 12p pin ongl with gray valet wire
Hello Jesse,
I am not sure what kind of a valet switch that you currently have for replacement, however all viper systems use a two wire connector, with one gray wire and one black wire and a blue connector on the end. All this does when you hit the switch is series, or connect the two wires. The brain reads the number of pulses that is receiving the specified timeframe and then completes the command based on the set number of pulses. This connector is a separate 2 pin connector from the 12 pin main harness. This will be located when looking at the 12 pin harness on the right side of the brain.
Mar 06, 2014 | Viper Vehicle Parts & Accessories
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
Feb 03, 2014 | Directed Electronics 479V Remote Gen 2...
Wiring diagram viper PC case
http://www.xoxide.com/xgbox-mge-viper-kr.html
http://www.xoxide.com/cases.html
hope this helps The MGE Viper Computer Case was been featured in Maximum PC Magazine December 2004 and granted a 9/10 score.
Jun 27, 2012 | Viper XG Red Viper2 Aluminum ATX Mid-Tower...
Where do I Connect the AC adapter on a Viper Dartboard
If its the same one shown next to question its on the lower right corner as you look at the board I use to have one like it.It also uses batterys if worse comes to worse
Apr 11, 2012 | Viper Gld Viper 787 Electronic Dart Board...
Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
My fans and lcd have quit working
pc doesnt power up? flaky PSU,memory or mainboard
http://www.aa1consulting.com
Jul 26, 2009 | XG Viper 2 ATX Mid-tower Gaming Case...
Front usb ports
Have a computer store look at it they may be able to help you put the wwires in the corect spot.
May 03, 2009 | XG Viper 2 ATX Mid-tower Gaming Case...
Two issues with this system
Hi eshort
When you press the buttons to operate the Cd drawers, do you still feel a click under your fingertip the same as the rest of the buttons. If not, the plastic piece may have broken away from behind the front panel assembly preventing the switches from operating be from the front panel. It may as you have already diagnosed be a part broken off the transport also.Only further investigation will determine this:) Can you still operate the unit from remote control?
The LCD display will use an incandescent lamp to back light it. this lamp will have failed. These are replaceable, the degree of difficulty varies from model to model. Pop the lip off and check if it is easily access. The worst cases need to have the LCD display removed to replace the lamp. Good Luck, thanks for checking with FixYa
regards
Graeme
Mar 11, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
XG Viper 2 ATX Mid-tower Gaming Case w/Acrylic Window Blue LED & 500W Power Supply - Silver (ET-CAV2-SL) ATX Mid-Tower Case Logo
437 people viewed this question
Top XG Computers & Internet Experts
David Payne
David Payne
Are you a XG Computer and Internet Expert? Answer questions, earn points and help others
