When i access the web configuration it prompts for a password i dont what to do...i know the password
The Linksys comes with web admin access disabled.
To enable it, pick up phone, dial **** then 723646# , when asked for password, dial 78778839# , when asked for value dial 1# then dial 1 to save.
Then, go to »192.168.0.1/admin/voice/advanced , enter user and password.
If you did a factory reset, you will need to call Linksys technical support.
After reset when i dial **** 110# it say's an ip od 0.0.0.0
if i dial **** 210# it say's 192.168.0.1 but access from WAN side
with option 7932# it is asking for password
i have tried password with 78778839# but it says invalid password.
SOURCE: LinkSys SPA 2102
try this out
power on your linksys
then pick up the phone connected to that linksys
no dile tone required
dial ****
when it says configuration menu
type 73738#
if ask for password then nothing can help you buddy
and if it says press 1 to save then press 1 and your device is reset with factory default
SOURCE: LINKSYS SPA-2102 CAN NOT FACTORY RESET, PASSWORD REQUIRED!!
You need to:
1) figure out where it's going for config file updates (e.g. http://ip address/path/filename (wireshark highly recommended for this)
2) once you have the filename, you need to find a "broken" copy of that CFG file. You may be able to use the broken sunrocket one (google linksys2102-sunrocket.cfg)
3) setup a webserver to it appears to be at the ip address above (there are a number of ways to do this - google sunrocket 2102 for some step-by-step instructions.
4) reboot the SAP with the DTMF codes
That all seem like too much? Then go to broadband reports.com and PM DogFace05 - he can remotely unlock your 2102, but there's a fee.
SOURCE: I need to hard rest
dial **** and 73738# and press 1 to confirm the resetting. wait for 1 minute
Whats the provider, sometimes they are provide locked :(
Same Problem
what is user in default
I get to the linkys cofig page but when i click admin, it asks for username and password. If I leave blank, it does not let me in
