Question about Sony VPL PX15 Multimedia Projector
My VPL-PX15 will not work.
I am in Kenya. I have a VPL-PX15 which I recently bought without a remote control. When I turn it on a weak light briefly shows and then goes off. Then the standby lamp blinks in green and soon turns red while the projector powers off. Please, assist with a solution. Email: smutea@publixafrica.com OR silasirea@yahoo.com
SOURCE: sony vpl cx5 no voltage to lamp
I downloaded the schematics and drawings for $US9.00 and found what I thought may have been a thermistor turned out to be a fuse. Obtained one from Sony spares and it is now OK. If it is possible would you guys know the value of the fuse [amp/milliamps??] If you are familar it is fuse 2P connected to C board, it looks like a small lump of plastic or diode block. The cost of the fuse is outragous from Sony. I hope I do not have to replace it again. However, if I do I would love the valua and I could see if I could get one from Radio shack or someplace similar. If I was not retired I would buy one and put it on a step tranny and watch the ampmeter for the blow current. But, thats life when you decide to retire. I believe the voltage value is 3volts??
Would appreciate any feed-back on the value of the fuse.
And I hope this may help others
Thanks and Good-day
Leckie
Posted on Mar 01, 2008
Marrie
  • 563 Answers
SOURCE: SOny VPL-EX1 turns on for a few minutes and then the Lamp /Cover LED and Power ON/Standby LED flashes.
Hi David
I think you should replace the lamp.
Posted on Mar 26, 2008
Marrie
  • 563 Answers
SOURCE: Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
  • 4234 Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
Correct code for universal remote will not turn off tv. On the 50" digital led model ELEFT502. Original remote always had a weak signal worked only when pointed a foot away from infared reciever. Then quit...
No universal remote control will work with any TVs as well as the original ones. If the original remote control do not get range, there are two reasons for it; and can be repaired to.
1. Battery weak [Replace with new batteries]
2. The infra-red light emitting diode at the front of the remote control is weak.[Can be replaced with a new one. It can be bought from most of the electronic spare part selling shops]
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Feb 06, 2015 | GE Televison & Video
I have a Sony VPL-PX15 I get an error saying Backup Battery Very Low. How do I replace it
there is not a Backup battery in this projector
pls check the lamp
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
http://www.lampdeng.com
Feb 26, 2014 | Sony VPL PX15 Multimedia Projector
How to reset sony projector vpl-es2 without remote control cause the panel key is lock?
Turn the projector on and leave in standby mode. To do this press the power on button for 10 seconds until the projector comes on.
To unlock the main panel keys, press the MENU button for 10 seconds.
Aug 05, 2011 | Sony VPL-CS7 Multimedia Projector
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Jul 04, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Sony VPL PX15
After much irritation at not being able to find a manual that told you how to do this... I found it!
1. Place your projecter in stanby mode
2. Press RESET
3. Press the LEFT arrow key
4. Press the RIGHT arrow key
5. Press ENTER
These steps will work. You might have to make sure that when you are selecting the left and right arrows, that you are facting the front of the projector. When I did this, I did it on the projector itself, not using the remote.
Hope this helps you.
Nov 10, 2008 | Sony VPL-PX15 LCD Projector Multimedia...
Fan remote operates fan, won't operate light
If you press and hold the light button, it will step up in brightness to max then back down to dark. Then when you press the button briefly it will turn off and then press button briefly again it will turn on at the intensity you had it at last. So if you are one tick from off you may not notice it is "on" because it is dark. A second possibility is that you replaced the bulbs with a compact flourescent and they are not always happy with adjustable brightness, often they will be on or off, no middle ground. I recommend sticking with old school bulbs in the fan.
Sep 21, 2008 | Universal Remote Control Hampton Bay...
Rim touched when turning
Put 1/2 spacer between your rims and brake drums.
Sep 07, 2008 | 1987 Suzuki Samurai
Green hue on screen
Hi there
If this shows on the image without a signal ( PC or Video ) then it could be one of your LCD's that need replacement
Feb 06, 2008 | Sony VPL-EX1 Multimedia Projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Can,t be able to turn my tv set to video mode
try some universal remote controls!
Dec 05, 2007 | Televison & Video
Sony VPL PX15 Multimedia Projector Logo
57 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
