Question about Cosco Beatrix Potter Playard Crib
Locking the top of cosco playpen - Cosco Beatrix Potter Playard Crib
How do I set up the costco play yard; I cannot make the side bars lock -- and there are no instructions with it.
Posted on Aug 12, 2009
5 Suggested Answers
SOURCE: cosco funyard playpen
what to do if toprails do not lock?
1. locate the handle in the center of the playard and lift the center of the floor completely up.
2.lift top rails until they are locked.
Posted on Dec 03, 2008
SOURCE: COSCO JUVENILE PLAYPEN
The sides are like elbows. You have to hyper-extend the elbows upward to get them to lock. It took my husband's strength on the longer sides.
Posted on Sep 23, 2009
SOURCE: Cosco Playpen
I just bought a Cosco Juvenile playpen. My entire family has tried and failed to set up this piece of junk. I don't understand why it won't lock in place and I don't understand why they advertise "quick and easy."
Posted on Jul 20, 2008
SOURCE: cosco playard playpen
Thanks for e-mailing me back. Actually my son and daughter figured it out. I was pushing in the button, but they found out just to pull the bar.
Thanks again for contacting me.
Posted on Jun 01, 2008
How do you fold a cosco playpen
1. Pull the mat out.
2. Lift bars under mat (you can't see them but can feel them)
3. Click buttons on the rods that make up the top railing (they are in the center of the rods and you can't usually see them either)
4. Fold
Dec 17, 2011 | Cosco Baby Gear
I cannot release the top bars on the Cosco playpen.
  • This is a safety feature.
  • When picking up the playpen you need pull pull the middle clear up first and then the side rails can be released.
  • When you set it up again make sure you set the rails up first and then push down the middle.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 05, 2011 | Cosco Beatrix Potter Playard Crib
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
Im babysitting my sister twins,and im tryin to set up their cosco playard,and it's not going well.alittle help please
If it looks something like this. Then you should be able to flatten out the inside middle (where the child would lay), pull on the top sides (with the buttons) until they lock into place. Then, put the mat into the playpen.
Mar 02, 2011 | Toys
I collapsed my Cosco Safari playpen and now I can not get the sides to stay up. They just remain collapsed. How do I fix this?
pull up the sides while the center is still up. If you flatten the center of the playpen first, the sides will not engage.
Apr 23, 2010 | Baby Gear
Putting up and taking down of Graco Avalon playpen
If you take the mattress pad out and collapse the base, you can then lock the sides. I was in the same boat as you. Very frustrating. Hope this helps.
Dec 12, 2008 | Baby Gear
Cosco Playpen
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
By the way, I've found it to be an exercise in frustration in trying to obtain an instruction manual from the manufacturer. I'm very disapopinted with this purchase and in particular this company.
Hope this helps!
Jul 01, 2008 | Cosco Beatrix Potter Playard Crib
Cosco playard playpen
hey guys, wat you have to do is keep the middle of the playpen up, the very middle thenyou lift up all the sides until they click...once all 4 sides have locked you press the middle of the play pen down and put the mat on top :) hope this helps
May 31, 2008 | Cosco Metal Crib
Mar 25, 2008 | Cosco Beatrix Potter Playard Crib
Cosco funyard playpen
Mar 17, 2008 | Cosco Beatrix Potter Playard Crib
Cosco Beatrix Potter Playard Crib Logo
988 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
