Question about Logitech (980240-0403) Microphone
I am trying to record a radio demo using my logitech microphone. should the mic be plugged into the back or front of the computer?
  • 4 Answers
SOURCE: mic filter
You can take a filter from an old speaker and arrange it in front of your mic.
Posted on Mar 12, 2008
Midwest-tech
  • 243 Answers
SOURCE: microphone troubleshooting
is it usb or standard 3.5mm if its 3.5mm the wires may have came loose this can be the same case with usb. let me know more info and i can better assist you.
thanks,
nate
Posted on Aug 22, 2008
rodamo
  • 224 Answers
SOURCE: Logitech microphone stuffed up my Computer Speakers!
go to sound icon in bottom task bar, double click on it,go to options,then properties,then click RECORDING,make sure you have a tick in MIC,then go to back to sound icon in bottom task bar,and adjust mic settings to suit
Rod
Posted on Sep 19, 2008
driveallnigh
  • 89 Answers
SOURCE: I have a Logitech Microphone. I plugged it into
Shouldn't be too hard to operate. Just turn it on. Of course you need a software program to use with it, like an instant messanger or to make a phone call. To try it out, go to start menu, all programs, accessories, entertainment, "sound recorder". Use that to make sure it is working. You can make adjustments by right clicking on the speaker on your taskbar and selecting, "adjust audio properites" and also selecting "open volume control" on the same menu.
Posted on Feb 26, 2009
  • 6 Answers
SOURCE: I have an OS 10.5 Mac and a Logitech desktop
Mac come with builtin Sound Recording Service. You need to follow these steps to record sound through your microphone.
  1. Click the Apple menu and select Control Panels; select Monitors & Sound
  2. Click the Sound icon.
  3. Under Sound Monitoring Source, select one of the seven input sources (where the sound will come from): Built-in Mic, External Mic, Sound In, Expansion Bay, CD, Zoomed Video, Internal Modem, RCA In, DAV Analog In, or PC Card. Some systems may not have all choices.
  4. Choose Sound Output Quality: 11.025, 22.050 or 44.100 KHz. Some systems may not have all choices.
  5. Click the Apple menu and select Simple Sound.
  6. Click the File menu and select New. You're presented with a window set up like the controls on a tape recorder.
  7. Click the Record button and start your sound (either speaking or singing into a microphone, or playing your CD, or whatever).
  8. Click the Stop button when you're finished. You can click Play to check what you recorded.
  9. Click Save. You're presented with a Save dialog box in which you can name the sound file and place it in whatever folder you like.
You are done. If SimpleSound isn't in the Apple menu, search for it with Sherlock (press Command-F). To play the new sound file later, just double-click its icon to open SimpleSound.
For further help please visit http://www.ehow.com/how_6538_record-sound-mac.html
Please do rate my solution.
Regards, Rashid.
Posted on Oct 28, 2009
Mic not working!
Go to logitech's website and look for the latest driver for your microphone:
http://www.logitech.com/en-us/support-downloads
Install it, plug in mic, load audacity/garageband, or any windows recording application, and ensure the mic input on the application is set to the plugged in logitech/labtec mic. Ensure the input volume is set to a level that responds when speaking into mic. Press record to see if it picks up the audio.
Apr 13, 2012 | Audio Players & Recorders
I have just brought a Logitec Webcam C120 and cannot get any sound. Do I have to get a microphone? When I do the sound test can't get any recording back.
Hi lynne_law ,
Many people mistakenly think that webcam can be used for audio as well as video transmission.
  1. Webcams don't usually come with microphones , therefore you would require a separate microphone for your voice recordings and voice chats.
  2. I would suggest you get a headset which would have the microphone option as well , or you can get a hand held mic.
  3. Once you get a new mic, you need to connect it to your computer by plugging in the mic in the appropriate slot , and by default the mic should work.
  4. If it does not work , you just need to change the microphone settings using the volume control option or audio settings via control panel.
Hope this helps ... ) Your feedback would be appreciated.
May 17, 2011 | Labtec Logitech 1200 Webcam
I plug in the microphoin into the computer and cannot get it to work. When I go to the Sound and Devices tab in Control Panel, I cannot see the Logitech device, only the defaul device that was there prior...
Is this a USB Mocrophone? If not, it will not show up any differently in your sound device manager.
If is is a 3.5mm headphone jack style mic, plug it into the pink connector on the back of your computer. If you are using Vista or Windows 7 right click the sound (volume) icon on your task bar. Select recording devices, then when the window pops up, try tapping the mic. When you locate the device that shows activity on the meter, right click it and select, make default device, and make defualt communication device. From here you can open the properties of that device and set the recording volumes to whatever you like. Your mic should now work with any applications that can use it, such as Skype.
Jan 07, 2011 | Logitech (980240-0403) Microphone
My logitech c300 microphone keeps distorting my voice. When I try to record a long note, the first second is normal volume level; after that the recorded note is a lot weaker. I sing at a constant...
reinstall the driver for logitech but first unplug the device, remove driver, reboot, install the driver, reboot, plug the mic back in ...
Aug 10, 2010 | Computers & Internet
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
Please help me
You need to check if the mic/s is working?
Are you certain the Logitech webcam has a built-in mic?
To check if the mic works go to Start - All programs - Accessories - Entertainment - Sound Recorder and test record your voice and play back to check, also try it with the laptop's built-in mic (if it has one) and the Logitech mic.
If both mics work then you have a choice of which one you can use in Skype, most likely the best one would be the Logitech one.
You need to configure your audio settings in Skype.
When you open Skype click on Tools - Options - Audio Settings and click on Select Microphone and select the microphone you are using and save the setting.
If you still have problems get back to me with all details and error messages.
May 15, 2009 | HP 510 Notebook
Rod
Sep 19, 2008 | Logitech (980240-0403) Microphone
Logitech microphone
Sounds like a physical problem with your input jack. Try plugging it into another microphone port. Most computers have at least two, one in back and one in front.
Sep 14, 2008 | Audio Players & Recorders
Audio not working in Windows Live Messenger
un cheak must plug it in or unplug it from mic input and plug back in tight cheak again might be bad mic then u could get a 10 doler one plug back in mic hole use cam for video only
Jan 24, 2008 | Logitech Webcam
Mic filter
Jan 20, 2008 | Logitech USB Desktop Consumer Microphone
Open Questions:
See all Logitech (980240-0403) Microphone Questions
Logitech (980240-0403) Microphone Logo
112 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
