Question about Sharp AR-507 Copier
L1-18 code Everything seems to move properly when copier is first turned on then code shuts copier down. I know its a finnisher problem but cant find anything wrong. any ideas?
    Scholar:
  • Sharp Expert
  • 120 Answers
Agreed, there is no L1-18 code listed in the service manual. You're sure you don't mean F1-18?
Posted on Jul 09, 2009
  • 143 Answers
I don't see a reference to a L1-18. A L1 code is a scanner feed problem. I only show a L1-00 code. Sorry.
Posted on Jul 07, 2009
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Canon ir7105 finisher unit is not working..!
The finnisher is only in disable by a a disable funcktion that switch the finnisher off.It just need a reset in the service mode.I am not alowed to give service info on the net.Ask your local service centre to clear the funcktion for you.You dont have to replace the finnisher.This is normally a paperjam or a opstical that prevented the trays to move up and down.Then the finnisher go to disable funcktion
Thanks for you support
Dec 12, 2009 | Canon imageRUNNER C3200 Copier
I have a ip5000 that has service error code 5100
I had the same problem. all i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine.
Tips:
#1 Move the cartridge holder back to the right manually, but carefully - close lid and turn the printer off, then on again.
#2 Move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Aug 10, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Fault has occured error code 103-208
First off. look around carefully and be certain everything is plugged in properly. Sometimes that code is caused my mis communication between the document feeder and machine, scanner and machine,finisher and machine, etc. I would follow all the connectors back and disconnect, then reconnect them.
If that doesn't resolve the problem, then remove the back cover and reseat all the connectors you can see on circuit boards.
With moving the machine, I am pretty sure you have a connector problem. But the 116 and 103 codes are related to software and mostly due to mis communications between the device peripherals.
Also on a hunch, just try to remove the RJ 45 network connector and turn the machine on. If there happens to be some odd job, something like an internet print job on that line, it will shut the machine off with that 116 code you reported.
Let me know and we will go from there.
Jun 02, 2009 | Xerox WorkCentre M-24 Color Copier
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 21, 2009 | Xerox Office Equipment & Supplies
I have a Canon Imagerunner 7095 copier and keep getting the same error code when I attempt to start the copier: Error Code E000532-8001. Any suggetsions
There is something wrong with the finnisher,check if the stapler unit is not stucked and in the home possition.Check if the finnisher trays is not stucked.
If it is an external finnisher you can unplug it and move it away from the machine.and you will be able to carry on copping wile wating for tech support.
Dec 19, 2008 | Office Equipment & Supplies
Error code E000584-0001
Hello Wyatt,
It took me a moment or two to find the explanation to this error. It appears you have a saddle stitch finisher as that distinguishes the error code. Canon does not lump all error codes together (concerning all available peripherals) in one spot. In brief, the code means that the second feed motor (which will initialize at start up/and only pertains to the saddle stich feature) was not recognized as acting properly. When the machine starts up it checks a tremendous amount of inputs and outputs and the second feed motor (m8) is one of those. The controller pcb of the finisher told the main controller of the copier that "m8" did not perform it's function. To simplify the diagnostics, either the motor did nut turn, or the shutter it drives is bound, or the finisher pcb has lost its mind, or best of all the copier is misinterpretting the data from the finisher pcb. I know this does not fix your problem, but at least you know where to look and what to look for. And if "copier dude" (which I am one) says you need a new SPLEEN you can tell him to go to hell !!! I wish I could be of more help.....and I can be for a nominal fee.......( plane tickets, hotel,mixed drinks) lol
Jun 27, 2008 | Canon imageRUNNER C3220 Color Copier
Initializing self test scanner
http://www.fixyourownprinter.com/forums/inkjet/19182
Nov 19, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Lid Error
Most systems either have a photo interrupter or a switch on the top to let the copier know its closed. Since you had it moved most likely they knocked it out of its position.Or broke the tab or plunger off.
Oct 17, 2007 | Konica Minolta DiALTA Di200 Copier
Cant move off manual settings screen
okay, unplug your internet modem for 15 min, keep the connection to the PS3, of course. do automatic settings, not manual, select easy but DO NOT GO FURTHER until you plug in your internet. Let it cycle, the modem may shut down. if/when it does, turn it on and continue. The PS3 should automatically find everything by itself. Confirm then test the settings.
Apr 30, 2007 | Sony Playstation 3 (PS3) Console
Sharp AR-507 Copier Logo
183 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
