Question about Refrigerators
GE REFRIG. MODEL#TFX30PRYAA. side by side both
13 year old GE REFRIG. MODEL#TFX30PRYAA. side by side both fridge&freezer do not cool properly. Ice tray remains cool water no ice cubes formed , fridge does not keep a can of soda cold at all. I cleaned the condensor coils& I also unplugged the unit for 24 hrs and replugged it and the unit worked for 3-4 days and then went back to original problem. I turned the the temp. control switch all the way to the right with a screw driver the fridge stopped and then restarted after approx. 45 min. Dear EXPERT what is the problem with my GE and what part needs fixing? THANKS FOR YOUR INPUT!
  • 1,543 Answers
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Posted on Jul 01, 2009
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
There is a sheet of ice forming in the ice cube tray and a larger one forming on the bottom of the freezer. The GE refrigerator is only 6 months old.
Because the sheet of ice is forming on the ice maker first it leads me to believe the water control valve for the ice maker is leaking water into the ice maker when it should be off. A filter installed before the dual water control valves would also be helpful. If you could find the model number of your refrigerator I would be able to tell you the part number. Sea Breeze
Nov 24, 2009 | GE Refrigerators
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Refrigerator not cooling, freezer is working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
My GE side by side model #GSS25LG refrig/freezer is not making ice cubes. The auger works but there is no water in the trays to be frozen. What turns the water on to fill the tray?
theres a solinoid valve in the back that opens up and the water goes to the ice maker, on the front theres a micro switch that sends the power down to the solinoid and makes it open up.
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator side won't cool
its iced up and needs to be thawed. you can use a hair dryer and make it fast in say 2 hours. the freezer side is blocked from admitting cool air to the fridge side. your defrost timer may be defective or you had a real humid situation that caused it to ice up.
Dec 08, 2008 | GE GSH25SGRSS Stainless Steel Side by Side...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
247 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
