Question about Dryers
My admiral capacity plus gas dryer no longer heats up. the light still works and it still tumbles. i have cleaned the vents, going outside and air flows through but does not get warm. the lint tray is also clear. i have reset the circuit breaker and still no heat.
    President:
  • 1,304 Answers
Ignitor is bad
Posted on Oct 05, 2009
Why would check vent light go on after replacing sensor and computer
Is the dryer vent blocked with lint? If there is a restriction in air flow in the vent system, the dryer will stop. Make sure the vent path is completely clean even in the wall where the vent hose connects.
Oct 07, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No air at vent
Sound like you need to replace the heating element.
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Jan 01, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer is a Fridgidaire Home Gallery...and the dryer tumbles, and heats in beginning of cycle but the heat will not continue to heat...tumbles normally. The vents have recently been cleaned.
if it's gas you have bad gas coils,if not blow out the vent line with a leaf blower if it's long from the back of dryer to the outside vent,also make sure the outside vent isn't blocked,then remove the lint filter and then remove the duct that it slides into and clean that out,let me know what you find,this came in under a frigerator,ha kinda messed me up
Sep 30, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
We have a Kenmore 80 gas dryer that tumbles, has hot air, but takes 2 hrs to dry. Vent line is clear, but lint filter is getting lint on back side of filter as well as normal amount on correct side. The...
Have you cleaned out the lint build-up from inside of the dryer yet? When you disconnect the vent from the back of the dryer, look inside the dryer. It probably have years of lint build up covering everything and needs cleaned out. You also will need to clean out the filter reservoir (with the filter removed) if you can get to it with a vacuum attachment. Be sure to unplug the cord and close the gas valve while you are working on it. Also be sure your vent flap outside is not stuck and allows hot air to open it when in use. Lastly, when you push the dryer back into place, make sure you don't squish the vent tubing if it is an expandable plastic or foil vent, which will restrict air flow and cause drying clothes to take longer. Hope this helps. Douglas
Jun 03, 2010 | Kenmore Dryers
No heat in gas dryer, gas good, elec good??
if the heat is on when the dryer is cold then shuts down after 15 to 30 minutes and doesn't lite for a long while you have bad gas coils,the gas should come on until it hits temp. then it shuts down,when the dryer calls for heat it will turn back on,if it stays on for short periods of time you might need to clean out the dryer,this will shut the gas down to soon,you need to clean out the duct that the lint filter slides into,blow out the vent line,make sure the air is blowing outside with nothing blocking it and vac out the inside of dryer where the motor is
Mar 12, 2010 | Maytag Dryers
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Dryers Logo
259 people viewed this question
Top Dryers Experts
Marvin
Marvin
