Fire tripping exhaust fans
  • 86 Answers
Check wiring properly
Posted on Mar 17, 2008
Lg tromm gas dryer not heating
Usually it's the igniter
Sep 08, 2017 | LG Dryers
When you first start up dryer everything is good. After burner shuts down just glow plug comes on but burner will not fire up.
Check for proper air flow. Pull exhaust hose from the back of the machine, turn on, form an opinion about air flow.....hook back up, turn unit on, go outside and see if the air volume is the same....Suspect air flow restriction, which will trip thermal sensors (rather than catch fire)...
Jul 05, 2011 | GE Dryers
I have a DC608 cordless nailer that will not fire the driver the driver does not move at all but everything else seems to be functioning properly Thanks Tim
You can go to this webpage and download the owner's manual which gives instructions:
You can also download a parts diagram and order parts here.
I looked through the manual and found that DeWalt's Brad Nailer does not require tools to remove jammed nails from the nose piece. I believe this is the problem with your nailer, unless it's empty. Some of these nailers will not fire if there's less than 6 nails in them.
Another feature on this nailer is the trip lock. It is a safety feature that prevents accidental firing. Any time you adjustments made to the nailer will automatically turn the trip lock to lock position. You'll find this lock on the right side, under the Dewalt label.
The instruction manual will explain all this.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Dewalt DC608K 18 Gauge 2-inch Cordless...
The Exhaust fan is not working, the unit still cools air then cuts out.
the unit is blowing cold air then tripping out, is it blowing hot air out the back? im sure you mean exhaust air as in hot air so the reason your unit is tripping out is that its overheating and the pressures in the rerigeration system are to high, so the safety trip cuts the unit off.
replace the motor
all the best
Jul 05, 2010 | Haier CPRD12XC7 Air Conditioner
The back of my dryer is getting very hot and actually tripped the breaker, also clothes taking forever to dry
Pull the exhaust vent off and check for obstructions, if there's no flow, all the heat is going to build up and also block any lint from escaping out the vent as well.
This can be a fire hazard as well. You may also need to open the dryer and clean out all the lint build up.
When you pull the pull flex hose off the back (the 4"diameter one) check in the back of the machine in the pipe and also in the flex tube. You may have to explore a little in the exhaust line to find the blockage...sounds like this is your issue...
Sep 16, 2009 | Dryers
As you pull the trigger slowly the tool cycles several times
It sounds like you have a contact trip trigger that you are trying to operate as a sequential trip. Sequential trip is when you have to put the tool against the work and pull the trigger every time, contact trip is when you pull the trigger and tap the nailer on the work and it fires. If you operate a contact trip like a sequential it will fire but it usually fire more than one nail. Your instruction manual will explain this, sometimes they give you two seperate triggers for the two modes or there is an adjustment on the nailer.
Aug 03, 2009 | Stanley Air Tools & Compressors
My heating element will come on but not stay I need a new element or thermostat?
this is a general Ideal,and may or may not be your problem.Its quite often a clog in the exhaust will make an element cycle off to quickly.Not enough air moves through the dryer,and it overheats.Its a safety feature that keeps your clothes from catching fire.You can check the exhaust for air flow,but sometimes a partial blockage is enough to trip the heater you have to really pull the hose off,and look up into the unit,and the hose.I had to tear a unit almost completely apart one time to find the clog.good luck,I hope that's the problem.
May 21, 2009 | Whirlpool LER4634PQ Electric Dryer
Dryer heat output is 148, but takes several runs to dry clothes
You most likely have a ventilation problem somewhere in your exhaust line. This can be very dangerous and a fire risk. You need to do a thorough check of your vent pipe and make sure it is clear and the exterior trap door is working freely.
Jan 26, 2009 | Amana ALE643RB Electric Dryer
Intertherm Furnace Will not stay on
possible dirty air filter low air flow causing high temp in fire box to trip limit switch or fan motor is bad hope this help let me know if you if this solved problem I may need more info
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Ventahood fire suppression systems
the wiring has to go to the microswitches
you can add up to three micro switches,they are located in the control box
there colors should be bl,brown and red
look for nc or no(you can depress the switch by hand to see when you press itup it shuts power
it has to be repeated for the light,plugs and make-up air
to pass inspection when you press up on switches the have to shut off electric lights and make up air
you dont need a relay.
the basic system is a contactor line and load runs exhaust and make up air power in power out.
you need power just for the contactor to pull in.
you need to add a switch break hot on contactor power
Jul 02, 2008 | Kitchen Ranges
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
