SOURCE: 2000 with kohler engine starter wont turn engine over.
Try adjusting the valves. Not an uncommon problem.
SOURCE: Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
SOURCE: Craftsman 42" 15.5 Kohler engine won't tunr over.
take it to your loca auto zone or whatever you have there tell them what it came off of they should be able to test it for you.hope this helped'
SOURCE: Craftsman II LT 4000 MOD # 917-255691 with a
Check the wire from the ignition switch to the small terminal on your solenoid with a volt meter to make sure you are getting current to the solenoid. If not try a "jumper wire" connected to the same terminals and see if it now cranks. If it does, replace the wire
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
