Question about Kenmore Freezers
Kenmore 253.26442100 freezer display only E, will not "hold" temperature and is not working.
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
  • 124 Answers
SOURCE: Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Posted on Nov 27, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
Controlfrk
  • 304 Answers
SOURCE: Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Posted on Sep 17, 2009
jyackle5
  • 8197 Answers
SOURCE: 253-21421104 Kenmore Freezer What is the
Your freezer is 20.3 cu.ft.
Good Luck
Posted on Aug 29, 2010
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
I have a 2007 model 253.264 upright Kenmore self-defrosting freezer. The control panel on the front door stopped working. No temperature reading and no way to adjust controls. The freezer is still
I have one out in the yard that is doing the very same thing. Works good but the door display is out. I looked underneath and all of the wires seem to be connected. The main control board is on the bottom as well. The battery is also new. You must have a broken wire between that control and the main board below. I imagine it has something to do the the connector that goes through the door.
Sep 21, 2012 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire freezer has ice accumulating and not freezing properly. Ice cream will not freeze.
Try turning the temperature control to off, unplug the electrical power cord from the power outlet, defrost the appliance, clean the condenser, plug the power cord into an electrical outlet, set the temperature control to a low setting, lay a thermometer in the freezer for a few hours and see what happens to the temperature in the machine.
Check the integrity of the seal of the door gasket by seeing how the door seal will hold a slip of paper in various locations along the freezer door gasket. A loose hold on the slip of paper shows an area where hot moist air can get into the freezer and cause ice build up.
Aug 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Cannot control internal temp plus clicking relay on control panel.
Where is the fast defrost button on Kenmore chest freezers?
Nov 20, 2007 | Freezers
Freezers Logo
196 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
