Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Runs 2 minute rinse only
We have a Whirlpool Gold dishwasher and two nights ago it started only doing a 2 minute only rinse. We have had an issue before where it was not draining properly that we solved by flipping the breaker off for 20 minutes that reset the board according to the repair guy. Any suggestions?
  • 64 Answers
Cloged airgap ?
unit may be in showroom mode
remove kick panel, retrieve service manual from kick panel
put unit into service test mode. let it run tests. it should reset
Posted on Jul 02, 2009
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool Gold dishwasher not cleaning dishes. It runs through the cycles and rinses, but dishes are not completely clean.
I had a similar problem with my last two dishwashers, with food still left on the dishes at the end of the cycle. What a nightmare. The most recent dishwasher is new, now the problem is solved. Here's what the manufacturer told me. Pour white vinegar (approximately 2 cups) into the dishwasher and run through the cycle. Buy some Cascade Complete and only use this type of soap for the dishwasher. Make sure you run a cup or two of the white vinegar through the dishwasher cycle once a week. My dishes are now clean and clear!!
May 26, 2011 | Whirlpool Dishwashers
My whirlpool gold dishwasher runs wash and rinse cycles, but there is no water in the bottom of the washer.
the drain hose had slipped off its clamp at the back and there was no air gap to prevent siphoning. Replaced clamp, and hopefully this works.
Nov 25, 2009 | Whirlpool Dishwashers
Two horizontal dashed line and won't start
A dishwasher operates in a hostile environment. Eventually the corrosive soap can damage the electrics & the electronics. If you have the skills, I suggest you turn off the breakler to the diswasher, then dissassemble the console & control board. Spray the contacts with WD40, & reassemble. The very sliding-action of dissassembly/reassembly should cure any contact issues. I hope that this helps.
Jul 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
"clean" light is blinking
Check the following:
1. Is the overfill protection float able to move up and down
freely? Press down to release.
2. Be sure the water supply is turned on to the dishwasher.
3. Check for suds in the dishwasher. If foam or suds are
detected by the dishwasher sensing system, the
dishwasher may not operate properly or may not fill with
water.
Suds can come from:
1. Using the incorrect type of detergent, such as
laundry detergent, hand soap, or dish detergent for
hand washing dishes.
2. Forgetting to replace the rinse aid dispenser cap
after filling (or refilling) the rinse aid, or spilling rinse aid into the tub (rinse aid causes suds to occur).
3. Using an excessive amount of dishwasher detergent.
Mar 16, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore dishwasher stops midway through
http://fixitnow.com/wp/2006/03/29/whirlpool-kitchenaid-kenmore-dishwasher-poor-cleaning/
Here is a good page that can help you resolve this issue and buy the parts needed
Feb 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool "(vinyl case) Quick Wash Plus" leaks from door's left side during rinse
yes replace the door seal and it will go back on the same way it comes off when you get new seal instructions should come with it. thank you for useing fixya please rate me
Oct 22, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold builtin dishwasher
Do not recommend premeasured tablets, usually too much soap. If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and make the soil sensor think the dishes are real dirty initiating additional wash cycles. Use rinse-aid for better drying performance
Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
241 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
