Temp gauge runs high then goes back to normal
Hello friend.
Steam from engine is usually blown head gasket or hairline fracture of piston liner letting water go where it should not and causing boiling of the water.. This will give similar problems.
The piston liner problem got me going once , Absolutly fine when engine idling for HOURS but when put under load and driven , the Temp FLEW up and steam came out,. Needs a workshop or good DIY Mechanic to take a look.at the engine. Probably nothing to do with AirCon.
SOURCE: m reg 1.6 zetec escort high emissions
you say the temp gauge doesn,t work could it be possible the thermostat is stuck open which would mean the engines running cold which means the auto choke won,t knock off normally if you short the temp switch wire to ground the gauge goes straight over to hot if it does,nt then the gauge is faulty but its usually the switch as far as the high c/o it could be as stated above or some thing as simple as an air cleaner c/o should be under 2.5 these carbs weren,t the best when they came out which type is it if its the v v i would get it overhauled
SOURCE: engine overheats when heater pipes connected
I think you could be right about there being air trapped in the system.
Or the heater core(radiator) is plugged.
Either way you need a pressurized radiator coolant pump to put the coolant in without air being trapped.
Although,i have seen it done by jacking the vehicle up high enough that the radiator was now higher than the heater core level, and then the coolant was put in.
But this is dangerous to try.
SOURCE: ford mondeo mk3, intermitent dumping of water from
You may have an air pocket in your system which some times happens. One way to get rid of it is to take the upper hose off on the engine side, fill your system with water until it runs out from your engine block, replace the hose, start your car turn you heater on and set to hi keep the radiator cap loose until the temp start to rise then close tight. Once the air pocket had been remover you can drain some of the water from the radiator using the lower drain plug and add antifreeze.
SOURCE: temp gauge goes up to hot then back down, up and down...
That is very possible.Your radiator could also be plugged,You water pump could be could be giving out or the head gaskets are bad..Those are all worse case scenario's But yes the thermostat could be the problem..I'd start with that then make sure your clutch is working properly..Hope this helps you and have a great day
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
