Question about Brother CS-8060 Computerized Sewing Machine
BOBBIN PROBLEM I TOO FOLLOW ALL STEPS TO FILL THE BOBBIN BUT IT STILL REFUSES TO SPOOL THE THREAD. IN FACT, I HEAR THE SOUND OF SPOOLING BUT THE BOBBIN IS NOT MOVING.
  • 46 Answers
Firstly check that you have the correct bobbin for your machine, there are many bobbins that will fit in the bobbin case and sew ok, but the hole in the centre is what matters. If you do not have an original try putting the bobbin on the winder spindle with a small piece of paper inside the centre of the bobbin so it is tight on the shaft.
If that does not work it usually means the winder rubber on the bottom of the cover is worn or stuck, this part often looks like a large O Ring.
Posted on Jul 02, 2009
Can't figure out how to fill the bobbin
hi Beverly.
you have not said what make and model.
but try this.
Always wind the bobbin before threading the machine and needle.
  1. Place spool of thread on spool pin.
  2. Slide spool pin holder/cap firmly over rim of spool to prevent thread from tangling.
  3. Push bobbin winder pin to far left if it is not already there.
More items...
Winding a Bobbin ' Singer Sewing
www.singerco.com/sewing-resources/bobbin-winding-other
or try this.
How to fill bobbin for sewing machine
How do you fill a bobbin on a Brother sewing machine? Use only the included bobbin or bobbins of the same type (part code: SA156, SFB (XA5539-151)).
  1. Turn on the sewing machine, and open the top cover.
  2. Place the bobbin on the bobbin winder shaft so that the spring on the shaft fits into the. ...
  3. Remove the spool cap that is inserted onto the spool pin.
More items...
How do I wind the bobbin? ' Brother
support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_pc420eus... Search for: How do you fill a bobbin on a Brother sewing machine?
or you could go and look at this link to see if it helps you out some more.
igniter button for SUNJOY PH018PSS Google Search
Nov 21, 2017 | Sewing Machines
When trying to load the bobbin with thread, only top half threads and is tangled. Has worked great till now.
Difficult to assess without a make & model.
The machine has a tensioner for the bobbin winder. Make sure that you are threading that tensioner before taking it to the bobbin winder. Also, sometimes the thread should make a complete loop around that tensioner (consult your owner's manual). Check that the thread spool is spinning the correct direction--most often the thread spool turns counter-clockwise on the spool pin. Running the thread the wrong direction could cause thread kinks or the thread plies to separate. Slow down the speed that you wind the bobbin. Fast speeds will cause the thread to stretch. Plus, if something goes haywire, you won't have a bobbin bouncing or thread flying all over the sewing room before you can stop the machine. Frequently, the bobbin will fill more in one area of the bobbin. You can gently guide the thread by pushing it up or down lightly with a pencil tip or other object to even the thread distribution on the bobbin.
Mar 31, 2016 | Sewing Machines
Thread a bobbin on a 5825c
If you mean the Singer 5285C, the manual is available from Singer here: http://www.singerco.com/uploads/download/449_5_6_8_10_slide.pdf . The diagram for winding the bobbin is on page 14 and inserting the bobbin is on page 15.
I'll attempt to walk through the steps. Push in on the indent on the hand wheel to lock the needle in the current position (note rotate the needle up first). Then with a spool on the spool pin and the cap securely holding the spool on the pin, snap the thread through the thread guide post (near the center back of the top of the machine). Then wind the thread clockwise through the bobbin tension guide (towards the center front of the top of the machine). Next run the thread through the hole in the bobbin (inside to outside). Place the bobbin on the bobbin spindle on the front of the machine near the right hand side of the machine. Hold onto the thread end at the bobbin and start pushing down of the foot controller. Fill the bobbin to the amount of thread that you need, or until it stops. Cut the thread going from the spool to the bobbin.. Remove the bobbin from the spindle and trim the thread end that is sticking through the hole in the bobbin. Press the hand wheel disc on the side opposite from the indent.
Inserting the bobbin requires you to lift the presser foot and have the needle in the highest position. Slide open the face plate and remove the empty or wrong color bobbin. With the hole in the bobbin up, pull about 4" of thread off the bobbin. Place the bobbin in the bobbin case and hold it down lightly with a finger. Guide the thread through the notch near the front of the bobbin case. Then lead the thread down into the slot on the left and then around the second notch. The thread should be heading towards the center of the bobbin (left to right). Pull the thread diagonally back to the back of the machine and slide the bobbin cover closed. The thread should be coming up through the opening between the cover and the needle faceplate. To pull up the bobbin thread, thread the needle and then hold onto this top thread. Rotate the hand-wheel towards you until the needle rises above the needle plate. Gently tug on the top thread to bring up the loop of thread. Separate the needle thread from the bobbin thread with your fingers. Bring the top thread through the left side opening in the presser foot and then pull both threads to the back of the machine.
I hope this helps.
May 24, 2013 | Sewing Machines
How to fill a bobbin on Virtuosa 150
Put the thread spool on the vertical spool holder with a sponge pad underneath. Wind the thread off the spool and through the small wire thread guide next to the spool holder. Take the thread across the top of the sewing arm to the tension unit just next to the gap in the case through which the thread is normally threaded - the tension unit looks like the top of a shiny screw without the slots in it. Wind the thread in a clockwise direction around the tension unit once and pull the thread with a bit of tension until it slips into the sprung gap around the underside of the shiny part. Slip the end of the thread through one of the holes in the bobbin and, preferably, wind a few turns on, then push the bobbin onto the bobbin winder shaft at the right-hand end of the top of the machine. Turn the bobbin clockwise by hand a few more times to make sure the thread is 'locked' onto the bobbin and then just push the lever adjacent to the bobbin winder to the left. To wind the bobbin, you then press the foot controller and either stop when you've got enough thread on the bobbin or let it stop automatically when full. Make sure you dont go so fast that the spool rattles-around on the spool holder otherwise this could spoil the way the bobbin gets filled.
Sep 28, 2011 | Bernina Virtuosa 150
My Husqvarna Designer I has an upper thread tension problem... the thread gets "caught" right at the beginning point of the threading process and the machine comes to a dead stop. There's major bobbin...
My guess is that it is the thread spooling off the reel that is the problem. Some of those specialty quilting cottons come on reels with plastic ends that have rough spots particularly knicks where you are supposed to "park" the thread end when you are done sewing. Run your fingers around the rim at each end of the reel and choose the smoother one to be the one closest to the threading mechanism. If neither end is suitable, flip the spool holder upwards so it is standing at a right angle to the machine, make sure the large spool holder is on then put the thread on - you won't need the smaller spool holder on top. Let the thread feed off from the right-hand side i.e. "under" the thread spool, across to the tension disks etc. Also be sure that the thread is not jumping out of that first thread tension slot.
Apr 26, 2010 | Husqvarna Designer I
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
I cant remember how to fill the bobbin with thread :(
Insert the empty bobbin case onto the bobbin winder in the sewing machine.
Step 2 Set the spool of thread onto the thread peg. Use the same thread you want to use on your material to obtain the best finished stitch.
Step 3 Follow the arrows or guides to take the thread from the spool to the empty bobbin.
Step 4 Start the thread around the bobbin in a clockwise direction.
Step 5 Push the small lever against the bobbin spool to hold it in place. This disengages the needle so it won't go up and down while winding the bobbin.
Step 6 Press the foot or knee pedal to start the winding process. Stop when you have enough thread on the bobbin for your project.
Step 7
Cut the thread between the thread spool and the bobbin. Insert the bobbin into the bobbin case so you can begin sewing.
Open to clarifications.
rate this.
Jan 10, 2010 | Janome Jem Silver 662 Mechanical Sewing...
Thread is not pulling off spool while trying to fill a bobbin.
There are a couple things that come to mind. If your plate is not pushed all the way up where it engages the metal tab on the bobbin, it will not wind properly. Second, if you are using a generic or an old bobbin, you need to replace it. I have seen many machines drive the owners crazy and it turned out to be a bad bobbin.
Jan 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
Brother CS-8060 Computerized Sewing Machine Logo
263 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
