Viewsonic LCD Tv - vertical lines on screen - flash through and change colour - picture comes good occasionally - but does not last before going to above problem N32240w -ie
  • pcliff069 Jul 01, 2009
    if this is correct is problem able to be fixed?
  • 583 Answers
You have defective Ribbon Wire thats connected to the LCD to Mother board..
Or you have loosed contact to Pin Ribbon Wire that needs to re solder.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jul 01, 2009
  • livetech Jul 01, 2009
    yes why not the problem can be solved ,if the
    pin ribbon wire connection is loosened then just resoldering will solve the
    issue.if the ribbon wire is defective.just replacing the wire will help solve
    it.
    in
    both the cases if you are not familiar with soldering then the manual tech is
    advisable.the wire costs approx 15 dollars plus the tech charges.
    thanks
    please
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Very blurry picture / vertical colour lines
It sounds that the LVDS cable; the cable that connects to T'Con board to LCD panel is loosely fitted. Check it first. If it is found OK, the panel itself should be suspected. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. Faulty screenshots of LCD TV screens, have been illustrated. Compare them to your TVs present screen view, and be sure. Check the site with patience.
Jun 25, 2013 | Sharp LC Televison & Video
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
