Why does my renault megane automatic suddenly lose speed when travelling and then will not ghange gears - it loses all power then will suddenly lurch forward?
SOURCE: My renault megane automatic is stuck in reverse and won't start
Hi all,
I have a 2002 Renault Megane 1.6 Convertible and experienced exactly the same fault. Needed a team effort but we found a very easy quick fix to this problem. If you take the plastic cover off from under the gear shifter, you will notice a release button covered by a rubber cover. Pressing this release button allows the gear shifter to move from its locked/jammed position. (This is not the fix but it helps with the fix).
If you are fortunate enough to have a 2nd person available, have them poke their head under the bonnet to watch the Gearbox cable move....while you are shifting the gear shifter inside the vehicle. Your partner will see that a cable with a plastic locking device (right hand side of the engine cover) has popped off the shifter for the transmission. Move the shifter until you can physically put the plastic locking device back on the shifter mechanism and your all good to go. No need for that new gearbox that you might have been quoted on!! An easy fix that I am surprised no mechanically minded professional/body in the world has volunteered the solution to. I wonder why????
SOURCE: Injection fault, Renault megane 1.4
I had same Problem with 03 Megane about 6 weeks ago
and the fault on mine was the one of the Coils had gone.
got replaced £270.00 later working fine....
just happened again with same message Check Injection.
RAC told me injection has gone, so now yet again back in the garage.. How i wish i never brought a Megane
SOURCE: renault megane cabriolet roof broken?????
just had the same problem with mine, here's what the problem was, the hydrolic fluid had gone bellow the min level indicator because of a slight leak to the ram, the reservoir is located in the back N/S boot. refill the the reservoir (Halfords do the hydrolic fluid for them) then you need to re-set the roof mecanism, after opening and closeing the back part of the car where the roof goes manually, and trying the switch a few times to reset the locking device with the micro switches, I managed to do it without spending too much cash. hope this helps anyone with roof trouble. -
SOURCE: renault megane engine light flashing and car is juddering.
I have 2 meganes im working on at the moment both have the same problem. the electrical falt light is on coz the pipe has snapped (or come off) under the bonnet on the passangers side close to the window (theres a black box about 2 inch wide the pipe connects underneath). if I reconect the pipe and grab the engien with both hands it wobbles and the pipe pulls off. I suspect this is coz one (or all) the engien mountings are shagged. and this will be the cause of the juddering when driveing in first and second gears. solutions iv have come across for juddering involve changeing the coil pack but thats nothing to do with the problem my 2 cars have as one of them has new coils. they are 1.6 petrol, p reg and s reg
SOURCE: we can't start our 2002 renault megane with the ke...
Hi
You should normally have two key cards, a simple test is necessary to come to the proper conclusion.
First of all insert one of the two key cards into the card reader examined what is written on the instrument panel if the message is card not detected
try the second key card, and if the second key card is, Detected then you have a problem with the first Key card.
With this small test you should come to the conclusion if there is a problem with the key card or the card reader.
This should answer your question, I hope I have been helpful.
